Hi all,
I have a beagelboard that execute an industrial application without
the need of uman interaction and without monitor.
Sometimes I need to shutdown the board but I only can to power off the
board unplugging the power cable.
Is there a way to generate a soft shutdown as if I run "halt" commend
in the console?
I am not sure if got what you exactly need but to turn off your Beagle
Board from the Linux terminal, it is necessary only to write: #shutdown -h now
"-h" means halt. So, it will keep off.
isn't there a way to customize the USER button?
you can of course hook up some functionality to the user button,
which could be to e.g. unmount and sync all drives so that you
can then remove the power safely.
