For what it’s worth, here are steps I documented for reliably using an ‘ath9k_htc’ usb wifi dongle with Angstrom (systemd-image):
Building and Installing ‘compat-wireless’ Drivers (on the Beaglebone itself):
- Prepare local environment for building drivers. Following instructions here: ‘http://nomel.org/post/30357133735/beaglebone-tutorial-how-to-compile-kernel-module’):
a. opkg install task-native-sdk
b. opkg install kernel-headers
c. opkg install kernel-dev
d. ‘ln -s /usr/src/kernel /lib/modules/3.2.30/build’ (Replace 3.2.30 with appropriate kernel version… Make sure the headers downloaded to ‘/usr/src/linux-3.2….’ match the actual kernel version ‘uname -r’, otherwise the modules built in this way will not work)
e. cd /usr/src/kernel
f. make scripts
- Download and build the ‘compat-wireless’ drivers. Following instructions here: (http://wireless.kernel.org/en/users/Download/stable/#compat-wireless_3.6_stable_releases):
a. mkdir ~/compatwireless
b. cd ~/compatwireless
c. wget http://www.orbit-lab.org/kernel/compat-wireless-3-stable/v3.6/compat-wireless-3.6.2-1-snp.tar.bz2
d. tar -xzvf compat-wireless-3.6.2-1-snp.tar.bz2
e. cd compat-wireless-3.6.2-1-snp
f. ./scripts/driver-select ath9k_htc
g. make (this step is redundant if the following line is run…)
h. make install-modules (Automatically copies the modules to the correct place)
i. Run ‘depmod -a’ to update the ‘known module dependencies’ list with the ones just made/copied.
- Alternately (much faster/better), cross-compile the wireless drivers on a host machine and transfer them across:
a. [From the host machine e.g. Ubuntu…]:
b. mkdir ~/compatwireless
c. cd ~/compatwireless
d. wget http://www.orbit-lab.org/kernel/compat-wireless-3-stable/v3.6/compat-wireless-3.6.2-1-snp.tar.bz2
e. tar -xzvf compat-wireless-3.6.2-1-snp.tar.bz2
f. cd compat-wireless-3.6.2-1-snp
g. ./scripts/driver-select ath9k_htc
h. Build with cross-compiler (using the kernel source git repo path as KLIB and KLIB_BUILD):
i. make ARCH=arm CROSS_COMPILE=arm-angstrom-linux-gnueabi- KLIB=~/angstrom/setup-scripts/build/tmp-angstrom_v2012_05-eglibc/work/beaglebone-angstrom-linux-gnueabi/linux-ti33x-psp-3.2.23-r14i+gitr720e07b4c1f687b61b147b31c698cb6816d72f01/git KLIB_BUILD=~/angstrom/setup-scripts/build/tmp-angstrom_v2012_05-eglibc/work/beaglebone-angstrom-linux-gnueabi/linux-ti33x-psp-3.2.23-r14i+gitr720e07b4c1f687b61b147b31c698cb6816d72f01/git [Note: Change paths to suit…]
j. Package up the module files and move to the target (Borrowing steps from here: http://wiki.chumby.com/index.php/Compat-wireless_driver_on_chumby#Cross-compile_compat-wireless_driver):
k. find ./ | grep ko$ | xargs tar cvjf wireless-compat_modules.tar.bz2
l. [On the beaglebone]:
m. cd /lib/modules/3.2.23
n. mv updates old-updates (only if there is an old version of the wifi drivers present…)
o. mkdir updates
p. cd updates
q. Copy from host machine:
r. scp bone@10.192.0.95:/home/bone/compatwireless/compat-wireless-3.6.2-1-snp/wireless-compat_modules.tar.bz2 ./
s. tar -xvf wireless-compat_modules.tar.bz2
t. Run ‘depmod -a’ to update the ‘known module dependencies’ list with the ones just made/copied.
- Download and copy the two firmware files ‘htc_7010.fw’ and ‘htc_9271.fw’ from http://linuxwireless.org/download/htc_fw/1.3/ to ‘/lib/firmware’:
a. cd /lib
b. mkdir firmware
c. cd firmware
d. wget http://linuxwireless.org/download/htc_fw/1.3/htc_7010.fw
e. wget http://linuxwireless.org/download/htc_fw/1.3/htc_9271.fw
Make sure to check the file ‘/var/lib/connman/settings’ and ensure that line after ‘[WiFi]’ reads ‘Enabled=true’
Reboot.
Plug in the usb-wireless dongle. Check ‘dmesg | tail’ to see that it is recognized and that the firmware files are properly transferred. Check ‘lsmod’ to see that all the ‘ath…’ modules have installed correctly.
Follow Steps here to verify wifi works (in client mode…): (http://support.criticallink.com/redmine/projects/arm9-platforms/wiki/USB_WiFi_Configuration?version=6)
a. opkg install wpa-supplicant
b. opkg install wireless-tools
c. opkg install kernel-module-rfkill (annoyingly, needs to update the kernel image – not required for kernel build versions 3.2.30 onwards)
d. In the following files:
/usr/share/dbus-1/system-services/fi.epitest.hostap.WPASupplicant.service
/usr/share/dbus-1/system-services/fi.w1.wpa_supplicant1.service
Change the “Exec=” line to be “Exec=/usr/sbin/wpa_supplicant -u -s -O /var/run/wpa_supplicant” in both files. (initially it is the same up to ’–u’)
e. wpa_supplicant –B –Dwext –iwlan0 –c/etc/wpa_supplicant.conf (runs wpa_supplicant in thebackground)
f. call ‘wpa_cli’, then call ‘status’ to see how the connection is going.
g. Sometimes it can take a long time to connect – perhaps removing connman service helps.
i. What definite helps is setting ‘ap_scan=…’ to ‘ap_scan=1’ in the ‘wpa_supplicant.conf’ configuration file.
