[SOLVED+PATCH] Beagleboard running Jack Audio Connection Kit
Normally jackd fails to run on the Beagleboard Angstrom distro when
audio capture is enabled. Jackd can be made to run if given the right
arguments.
# jackd -d alsa -p 256 -n 4 -P hw:0 -C hw:0 -S -r 48000
Important settings seem to be -p 256 -n 4.
Tested on Rev C4 with jack-server_0.118.0-r0.5_armv7a.ipk .
I have a patch which makes these working values the default for jackd
in angstrom. Who can review and commit it?
arguments.
Great work.
I guess Koen is reading your message anyway. But normally you should
send patches for Ȧngström to developer list [1].
Paul
[1] http://www.angstrom-distribution.org/contact
Thanks for the pointer.
BTW I was also able to get Jack started under Ubuntu 10.04 lucid using
these parameters.
Thanks!
Best,
Ed
I'm running jackmp, jack_lsp just hangs there - Ubuntu on a C3.
Slightly off-topic I can't get anything recorded from the Mic, neither on Ubuntu nor on Angstrom narcissus. It seems to record a wav file OK, but on playback I just get white noise.
root@beagleboard:~# jackd -d alsa -p 256 -n 4 -P hw:0 -C hw:1 -S -r 48000 &
[1] 1792
root@beagleboard:~# jackdmp 1.9.7
Copyright 2001-2005 Paul Davis and others.
Copyright 2004-2010 Grame.
jackdmp comes with ABSOLUTELY NO WARRANTY
This is free software, and you are welcome to redistribute it
under certain conditions; see the file COPYING for details
JACK server starting in realtime mode with priority 10
root@beagleboard:~# jack_lsp
I am using jackmp as I especially need jack_connect, no problems on openSUSE 11.3 or Kubuntu 10.04 LTS x86_64 boxes.
Regards
Sid.
