Some more details on this build failure
Well I located what looks like more detailed logs of the failure, and they are here:
/home/scratch/beagle/setup-scripts/build/tmp-angstrom_2010_x-eglibc/work/beaglebone-angstrom-linux-gnueabi/systemd-image-1.0-r0/temp
But it's still useless, the most recent log file dies here:
pam (>= 1.1.5), pam-plugin-lastlog
Provides:
Status: install user installed
Section: base utils
Architecture: armv7a
Maintainer: Angstrom Developers <angstrom-distro-devel@linuxtogo.org>
++ uniq
++ sort
++ sed -e 's/^Depends: //' -e s/,//g -e 's:([=<>]* [0-9a-zA-Z.~\-]*)::g'
++ opkg-cl -f /home/scratch/beagle/setup-scripts/build/tmp-angstrom_2010_x-eglibc/work/beaglebone-angstrom-linux-gnueabi/systemd-image-1.0-r0/opkg.conf -o /home/scratch/beagle/setup-scripts/build/tmp-angstrom_2010_x-eglibc/work/beaglebone-angstrom-linux-gnueabi/systemd-image-1.0-r0/rootfs --force-overwrite info shadow
++ grep '^Depends'
+ deps='libpam-runtime pam-plugin-env shadow-securetty pam-plugin-faildelay pam-plugin-securetty pam-plugin-limits pam-plugin-nologin pam-plugin-motd pam-plugin-shells pam-plugin-group pam-plugin-mail libc6 pam-plugin-rootok libpam pam-plugin-lastlog'
+ for dep in '$deps'
+ sed 's:OPP:->:g'
+ sed -e s:-:_:g -e 's:\.:_:g' -e s:+::g
+ echo 'shadow OPP libpam-runtime;'
+ echo 'shadow OPP shadow-securetty;'
+ sed 's:OPP:->:g'
+ echo 'shadow OPP pam-plugin-faildelay;'
+ sed 's:OPP:->:g'
+ echo 'shadow OPP pam-plugin-securetty;'
And that's all it says! There's no actual error message in there, no hint of WHY it might be failing there.
The actual bitbake output is the same as above, with this appended:
NOTE: package systemd-image-1.0-r0: task do_rootfs: Failed
ERROR: Task 8 (/home/scratch/beagle/setup-scripts/sources/meta-angstrom/recipes-images/angstrom/systemd-image.bb, do_rootfs) failed with exit code '1'
NOTE: Tasks Summary: Attempted 3282 tasks of which 3281 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
Why would pam be failing to build silently? How could I find out what specifically about this would be failing?
I'm on a fresh build from setup_scripts commit 37ecb7348ff252ec8ba3ee8b2418864f791e8c80 , MACHINE=beaglebone
Thanks.
-ken
I’m running into the same problem:
ERROR: Task 8 (/home/jerrill/projects/angstrom/setup-scripts/sources/meta-angstrom/recipes-images/angstrom/systemd-image.bb, do_rootfs) failed with exit code ‘1’
NOTE: Tasks Summary: Attempted 3283 tasks of which 1502 didn’t need to be rerun and 1 failed.
Summary: There were 71 WARNING messages shown.
I’m running the following:
MACHINE=beaglebone ./oebb.sh bitbake systemd-image
Jerrill
