yossibs wrote:
I wonder about the performance of flashlite application in high
resolution (e.g. XGA 1024x768) when running on the OMAP3.
Did anyone tried to run any flashlite application in such resolution
or even higher than that?, if yes could you please put some lite on
that experience?, how was the responsiveness?, how smooth were the
moves?, ...
You cannot answer that question, this totally depends on the actual
Flash content that is to be played.
But, there are products out that implement FL on an OMAP3 and also
output similar resolutions, so i seems doable.
