spi_sync kernel NULL pointer error
I have problem when I do the following:
status = spi_sync(test_dev.spi_device, &test_ctl.msg);
I get the error:
"Unable to handle kernel NULL pointer dereference at virtual address
00000000"
It seem like the problem related to follow when the kernel* try to
execute it, this is part of spi_sync() in spi.c
wait_for_completion(&done);
What could cause this issue? The following is my SPI driver code.
[CODE]
#define SPI_BUFF_SIZE 16
#define USER_BUFF_SIZE 128
#define SPI_BUS 1
#define SPI_BUS_CS1 1
#define SPI_BUS_SPEED 1000000
const char this_driver_name[] = "test";
struct test_control {
  struct spi_message msg;
  struct spi_transfer transfer;
  u8 *tx_buff;
  u8 *rx_buff;
static struct test_control test_ctl;
struct test_dev {
  struct semaphore spi_sem;
  struct semaphore fop_sem;
  dev_t devt;
  struct cdev cdev;
  struct class *class;
  struct spi_device *spi_device;
  char *user_buff;
  u8 test_data;
static struct test_dev test_dev;
static void test_prepare_spi_message(void)
  printk(KERN_ALERT "@test_prepare_spi_message\n");
  spi_message_init(&test_ctl.msg);
  printk(KERN_ALERT "@test_prepare_spi_message p1\n");
  /* put some changing values in tx_buff for testing */
  test_ctl.tx_buff[0] = test_dev.test_data++;
  test_ctl.tx_buff[1] = test_dev.test_data++;
  test_ctl.tx_buff[2] = test_dev.test_data++;
  test_ctl.tx_buff[3] = test_dev.test_data++;
  memset(test_ctl.rx_buff, 0, SPI_BUFF_SIZE);
  test_ctl.transfer.tx_buf = test_ctl.tx_buff;
  test_ctl.transfer.rx_buf = test_ctl.rx_buff;
  test_ctl.transfer.len = 4;
  printk(KERN_ALERT "@test_prepare_spi_message p2\n");
  spi_message_add_tail(&test_ctl.transfer, &test_ctl.msg);
static int test_do_one_message(void)
  int status;
  printk(KERN_ALERT "@test_do_one_message\n");
  if (down_interruptible(&test_dev.spi_sem))
  return -ERESTARTSYS;
  if (!test_dev.spi_device) {
    up(&test_dev.spi_sem);
    return -ENODEV;
  test_prepare_spi_message();
  printk(KERN_ALERT "@test_do_one_message p1\n");
  if(&test_ctl.msg == NULL )
    printk(KERN_ALERT "@test_do_one_message test_ctl.msg NULL\n");
    return -ENODEV;
  if(test_dev.spi_device !=NULL)
  else
    printk(KERN_ALERT "@test_do_one_message NULL\n");
    return -ENODEV;
  printk(KERN_ALERT "@test_do_one_message p2\n");
  return status;
static ssize_t test_read(struct file *filp, char __user *buff, size_t
count,
      loff_t *offp)
  size_t len;
  ssize_t status = 0;
  printk(KERN_ALERT "@test_read\n");
  if (!buff)
    return -EFAULT;
  if (*offp > 0)
    return 0;
  if (down_interruptible(&test_dev.fop_sem))
    printk(KERN_ALERT "@test_read test_dev.spi_device is NULL\n");
  else if (!test_dev.spi_device->master)
    printk(KERN_ALERT "@test_read spi_device->master is NULL\n");
  else
    printk(KERN_ALERT "@test_read %s ready on SPI%d.%d\n",
      this_driver_name,
      test_dev.spi_device->master->bus_num,
      test_dev.spi_device->chip_select);
  //len = strlen(test_dev.user_buff);
  printk(KERN_ALERT "@test_read p1\n");
  status = test_do_one_message();
  if (status)
    sprintf(test_dev.user_buff,
    "test_do_one_message failed : %d\n",
    status);
  else
    "Status: %d\nTX: %d %d %d %d\nRX: %d %d %d %d\n",
    test_ctl.msg.status,
    test_ctl.tx_buff[0], test_ctl.tx_buff[1],
    test_ctl.tx_buff[2], test_ctl.tx_buff[3],
    test_ctl.rx_buff[0], test_ctl.rx_buff[1],
    test_ctl.rx_buff[2], test_ctl.rx_buff[3]);
  if (len < count)
    count = len;
  if (copy_to_user(buff, test_dev.user_buff, count)) {
    printk(KERN_ALERT "test_readoned(): copy_to_user() failed\n");
    status = -EFAULT;
  } else {
    *offp += count;
    status = count;
  up(&test_dev.fop_sem);
  return status;
static int test_open(struct inode *inode, struct file *filp)
  int status = 0;
  printk(KERN_ALERT "@test_open\n");
  if (!test_dev.user_buff) {
    test_dev.user_buff = kmalloc(USER_BUFF_SIZE, GFP_KERNEL);
      status = -ENOMEM;
  return status;
static int __devinit test_probe(struct spi_device *spi_device)
  struct spi_master *spi_master;
  int status = 0;
    return -EBUSY;
  printk(KERN_ALERT "@test_probe\n");
  spi_master = spi_busnum_to_master(SPI_BUS);
  if (!spi_master) {
    printk(KERN_ALERT "spi_busnum_to_master(%d) returned NULL\n",
      SPI_BUS);
    printk(KERN_ALERT "Missing modprobe omap2_mcspi?\n");
    return -1;
  spi_device = spi_alloc_device(spi_master);
  if (!spi_device) {
    put_device(&spi_master->dev);
    printk(KERN_ALERT "spi_alloc_device() failed\n");
    return -1;
  spi_device->chip_select = SPI_BUS_CS1;
  spi_device->max_speed_hz = SPI_BUS_SPEED;
  spi_device->mode = SPI_MODE_0;
  spi_device->bits_per_word = 8;
  spi_device->irq = -1;
  spi_device->controller_state = NULL;
  spi_device->controller_data = NULL;
  strlcpy(spi_device->modalias, this_driver_name, SPI_NAME_SIZE);
  test_dev.spi_device = spi_device;
/* status = spi_add_device(spi_device);
  if (status < 0)
    spi_dev_put(spi_device);
    printk(KERN_ALERT "spi_add_device() failed: %d\n",
    status);
  put_device(&spi_master->dev); */
  printk(KERN_ALERT "@test_probe test_dev.spi_device: (%d)
\n",&test_dev.spi_device);
  return 0;
static int test_remove(struct spi_device *spi_device)
    return -EBUSY;
  printk(KERN_ALERT "@test_remove\n");
  test_dev.spi_device = NULL;
  return 0;
static struct spi_driver test_driver = {
  .driver = {
    .name = this_driver_name,
    .owner = THIS_MODULE,
  .probe = test_probe,
  .remove = __devexit_p(test_remove),
static int __init test_init_spi(void)
  int error;
  printk(KERN_ALERT "@test_init_spi\n");
  test_ctl.tx_buff = kmalloc(SPI_BUFF_SIZE, GFP_KERNEL | GFP_DMA);
  if (!test_ctl.tx_buff) {
    error = -ENOMEM;
    goto test_init_error;
  test_ctl.rx_buff = kmalloc(SPI_BUFF_SIZE, GFP_KERNEL | GFP_DMA);
  if (!test_ctl.rx_buff) {
    error = -ENOMEM;
  error = spi_register_driver(&test_driver);
  if (error < 0) {
    printk(KERN_ALERT "spi_register_driver() failed %d\n", error);
  return 0;
test_init_error:
  if (test_ctl.tx_buff)
    kfree(test_ctl.tx_buff);
    test_ctl.tx_buff = 0;
  if (test_ctl.rx_buff)
    kfree(test_ctl.rx_buff);
    test_ctl.rx_buff = 0;
  return -1;
static const struct file_operations test_fops = {
  .read = test_read,
  .open = test_open,
static int __init test_init_cdev(void)
  int error;
  printk(KERN_ALERT "@test_init_cdev\n");
  test_dev.devt = MKDEV(0, 0);
  error = alloc_chrdev_region(&test_dev.devt, 0, 1, this_driver_name);
  if (error < 0) {
    printk(KERN_ALERT "alloc_chrdev_region() failed: %d \n",
      error);
    return -1;
  cdev_init(&test_dev.cdev, &test_fops);
  test_dev.cdev.owner = THIS_MODULE;
  error = cdev_add(&test_dev.cdev, test_dev.devt, 1);
  if (error) {
    printk(KERN_ALERT "cdev_add() failed: %d\n", error);
    unregister_chrdev_region(test_dev.devt, 1);
    return -1;
  return 0;
static int __init test_init_class(void)
  printk(KERN_ALERT "@test_init_class\n");
  test_dev.class = class_create(THIS_MODULE, this_driver_name);
  if (!test_dev.class) {
    printk(KERN_ALERT "class_create() failed\n");
    return -1;
  if (!device_create(test_dev.class, NULL, test_dev.devt, NULL,
      this_driver_name)) {
    printk(KERN_ALERT "device_create(..., %s) failed\n",
      this_driver_name);
    class_destroy(test_dev.class);
    return -1;
  return 0;
static int __init test_init(void)
  memset(&test_dev, 0, sizeof(test_dev));
  memset(&test_ctl, 0, sizeof(test_ctl));
  sema_init(&test_dev.spi_sem, 1);
  sema_init(&test_dev.fop_sem, 1);
  if (test_init_cdev() < 0)
    goto fail_1;
  if (test_init_class() < 0)
    goto fail_2;
  if (test_init_spi() < 0)
    goto fail_3;
  return 0;
fail_3:
  device_destroy(test_dev.class, test_dev.devt);
fail_2:
  cdev_del(&test_dev.cdev);
fail_1:
  return -1;
module_init(test_init);
static void __exit test_exit(void)
  spi_unregister_device(test_dev.spi_device);
  spi_unregister_driver(&test_driver);
  if (test_dev.user_buff)
    kfree(test_dev.user_buff);
module_exit(test_exit);
[/CODE]
this is from my devkit8000_spi_board_info[
[CODE]
static struct spi_board_info devkit8000_spi_board_info[] __initdata =
    .modalias = "ads7846",
    .bus_num = 2,
    .chip_select = 0,
    .max_speed_hz = 1500000,
    .controller_data = &ads7846_mcspi_config,
    .irq = OMAP_GPIO_IRQ(OMAP3_DEVKIT_TS_GPIO),
    .platform_data = &ads7846_config,
    .modalias = "spike",
    .bus_num = 1,
    .chip_select = 1,
    .max_speed_hz = 2500000, // 25MHz
    .mode = SPI_MODE_0,
[/CODE]
