SPI testing
I consolidated the patches from the earlier SPI thread into one.
Hopefully, I didn't make any mistakes. This is (basically) against the
current kernel used by Angstrom.
So far, I have booted it and confirmed the existence of the dev nodes.
Philip
spi-test.patch (8.55 KB)
I am also trying to make the spi work, so I am interested in your work.
I have OpenEmbeded working and I use the online generated version of
Angstrom, could you explain me how to use your patch in this environment
or how to compile it in a standalone module ?
Looking forward to your answer.
Iatrides Clemént
Philip Balister a écrit :
I've attached a diff of my OE directory. It has the kernel bb file
changes and the defconfig changes. You need to put the patch I posted
earlier in packages/linux/linux-omap-2.6.28/beagleboard/spi-test.patch
Then bitbake -c rebuild linux-omap.
I have data coming out and am viewing it on the scope. Next week, I'll
start looking at reading data. This seems to be the part that causes
problems...
Philip
spi-oe.patch (2.65 KB)
I used theses patchs and I see the two /dev/spidev files but I was
unable to get an output on de expansion header pin. I tested with echo
and cat, but also with a smal C program. Is there any other
configuration I must do to use theses SPI Ports ?
IATRIDES Clément
Compile spidev_test.c found in the kernel Documentation/spi directory
with something like:
/home/balister/oe/tmp/cross/armv7a/bin/arm-angstrom-linux-gnueabi-gcc
-o spidev_test spidev_test.c
This assumes you are using OE to build the rootfs.
Philip
I builded with de new patch posted and I am not able to see any signal on the clock miso mosi or cs pins of spi3. I builded the spidev_test progam as explained and maby it is a pin mux problem did you do any thing else ?
IATRIDES Clément
2009/2/18 Philip Balister <philip.balister@gmail.com>
You will need to run "bitbake -c rebuild u-boot" and update u-boot on
your SD card. U-boot is in
tmp/deploy/glibc/images/beagleboard/u-boot-beagleboard.bin. U-boot
contains the pinmux setup now.
Also, I have MLO and U-boot on the boot partition of the SD card, I'm
not sure what the "standard" method is now :slight_smile:
Philip
