Hi all,
I’m attempting to get a 2.8" TFT LCD 2.8 TFT LCD with Cap Touch Breakout Board w/MicroSD Socket [EYESPI Connector] : ID 2090 : $29.95 : Adafruit Industries, Unique & fun DIY electronics and kits working on my PocketBeagle.
Using bb.org-overlays/src/arm/PB-simplegaming.dts at PB-simplegaming · jadonk/bb.org-overlays · GitHub as a reference I made bb.org-overlays/src/arm/PB-SPI1-ADAFRUIT28-TFT.dts at adafruit28 · AnthonyDiGirolamo/bb.org-overlays · GitHub
Then I updated /boot/uEnv.txt with
###Custom Cape
dtb_overlay=/lib/firmware/PB-SPI1-ADAFRUIT28-TFT.dtbo
and ran:
cd ~/bb.org-overlays
./install.sh
On reboot dmesg shows:
[ 37.071131] fbtft: module is from the staging directory, the quality is unknown, you have been warned.
[ 37.154982] fb_ili9341: module is from the staging directory, the quality is unknown, you have been warned.
[ 37.217569] fbtft_of_value: buswidth = 8
[ 37.217602] fbtft_of_value: debug = 1
[ 37.217611] fbtft_of_value: rotate = 0
[ 37.217619] fbtft_of_value: fps = 30
[ 37.217942] fb_ili9341 spi1.0: gpio_request_one(‘reset-gpios’=27) failed with -16
[ 37.417422] fb_ili9341: probe of spi1.0 failed with error -16
And /dev/fb0 doesn’t exist.
I then tried:
sudo rmmod fbtft_device fb_ili9341 fbtft
sudo modprobe fbtft_device name=adafruit28 busnum=1 cs=1 rotate=90 gpios=dc:65,reset:27
And dmesg reports:
[ 541.705866] fbtft: module is from the staging directory, the quality is unknown, you have been warned. [ 541.723630] fbtft_device: module is from the staging directory, the quality is unknown, you have been warned. [ 541.726930] spi spi1.0: ili9341 spi1.0 32000kHz 8 bits mode=0x00 [ 541.726961] spidev spi2.0: spidev spi2.0 24000kHz 8 bits mode=0x00 [ 541.726975] spidev spi2.1: spidev spi2.1 24000kHz 8 bits mode=0x00 [ 541.727716] fbtft_device: GPIOS used by 'adafruit28': [ 541.727731] fbtft_device: 'dc' = GPIO65 [ 541.727738] fbtft_device: 'reset' = GPIO27 [ 541.727754] spi spi1.0: ili9341 spi1.0 32000kHz 8 bits mode=0x00 [ 541.727765] spidev spi2.0: spidev spi2.0 24000kHz 8 bits mode=0x00 [ 541.727776] spidev spi2.1: spidev spi2.1 24000kHz 8 bits mode=0x00 [ 541.727787] spi spi1.1: fb_ili9341 spi1.1 32000kHz 8 bits mode=0x00 [ 541.778825] fb_ili9341: module is from the staging directory, the quality is unknown, you have been warned. [ 541.796831] fbtft_of_value: buswidth = 8 [ 541.796862] fbtft_of_value: debug = 1 [ 541.796871] fbtft_of_value: rotate = 0 [ 541.796879] fbtft_of_value: fps = 30 [ 541.797216] fb_ili9341 spi1.0: gpio_request_one('reset-gpios'=27) failed with -16 [ 541.820918] fb_ili9341: probe of spi1.0 failed with error -16 [ 541.821383] fb_ili9341 spi1.1: fbtft_request_gpios: gpio_request_one('dc'=65) failed with -16 [ 541.842127] fb_ili9341: probe of spi1.1 failed with error -16
Does anyone know what I’m missing? This page BeagleBone Black · notro/fbtft Wiki · GitHub mentions:
An unfortunate sideeffect is that capemgr also adds a platform device using the same DT node as the spi device:
$ ls -l /sys/devices/ocp.3/481a0000.spi/
total 0
drwxr-xr-x 3 root root 0 Aug 21 19:18 0.lcd@0
This is not a problem for regular spi drivers, but the FBTFT drivers does also support platform devices. This results in the driver probing this device as well. But the probing fails because the gpio has already been requested by the spi device. So, not a functional problem, but rather a cosmetic one with logging of errors in the kernel log that are not actual errors.
But for me there is no /dev/fb0 and I’m not sure what to try next. For reference I’m running:
$ uname -a
Linux beaglebone 4.4.110-ti-r142 #1 SMP Mon Jan 8 19:06:43 UTC 2018 armv7l GNU/Linux
Thanks very much for any help!
