can anyone pls guide me to run spidev_test.c on beagleboard x, a3?
currently i have done
ported linux-2.6.32 with spi patch form http://elinux.org/BeagleBoard/SPI/Patch-2.6.32
i m able to see in /dev
spidev3.0,3.1,4.0
when i executed the spidev_test.c i m getting only zeros nothing else
pls help me .. i really get frustrated
What are you expecting? If you don't have anything connected to the
relevant SPI lines, you will likely get garbage. That being said, I
thought this garbage would be ones, but perhaps I'm misremembering. I
think the easiest test would be to tie SIMO and SOMI. This should act as
a sort of loopback test.
hi ben
i have already tested spidev_test.c by shorting SIMO and SOMI..
i m still getting zeros when i try to execute
i found that CONFIG_OMAP_MUX was not set in my .config .
when i enabled that ,it was failed to mount the rootfs while booting.
if spi is working for u then pls send the .config file for the kernel
version u tried successfully.
Do you have access to an oscilloscope? If so, throw it on the SIMO pin
and see if you are seeing any output. A multimeter would also probably
serve in a pinch, provided you modified spidev_test.c to continuously
stream data. This way we can determine whether it's the input or output
side of things failing.
hi
i ran the spidev_test.c for different combinations....... tx=all
0x00 , all 0xff
but every time i m getting SIMO=1.8V SOMI=1.8V but output=0.
i tested it with v2.6.32...........mainline
can u tell me on which kernel version spi works fine?
if u have tested it fine can u give the steps u followed??
I am using 2.6.33 with the patch available on the BeagleBoard/SPI wiki
page[1]. I did not do anything beyond simply applying the patch and
configuring the kernel.
hi ben
i tried v2.6.33 mainline kernel with config-2.6.33-tracker… but
surprisingly it failed to mount the filesystem.
i tried with 2gb, 4gb sd card with partition as recommended in http://code.google.com/p/beagleboard/wiki/LinuxBootDiskFormat,.…
is there any prebuilt uImage available with spi support for xm?
pls help me out
The 2.6.32 version of the patch looks wrong. You have to set SPI Clock Pins to _INPUT_ to be able to read data back on MISO.
Take a look at the 2.6.37 version for a correct implementation. This issue has been added to the Technical Reference Manual[1] in its latest Revision F as well.
Oh no! Thank you very much for pointing this out. I must have uploaded
the wrong patch iteration. At this point I think I'll just take down the
2.6.32 patch. The 2.6.37 patch should apply cleanly against earlier
versions anyways.
Hmmm, I haven't seen this error before but I'd probably try bumping the
kernel to perhaps 2.6.34 or 2.6.35. Generally this is the approach I
take when there is a strange issue like this; sometimes things improve,
sometimes they regress further. It's worth a try though. Just git merge
the v2.6.34 tag and run make oldconfig and hopefully you'll be all set.
Sorry it's been so difficult to get this up and running.
Hi, I tried many times to install Angstrom on a beagleboard rev C2 by Narcissus but I was no able to see the GUI. After the login I can see only black screen with moving mouse arrow. So I decided to install the rootfs at http://www.angstrom-distribution.org/demo/beagleboard/ and then installing what I need by opkg. Is that the right way? I’m trying to config the beagleboard for the connection using VNC and ethernet over USB, but I can’t use the module g_ether…
Please look these messages …
hi,
i finally tried with v2.6.37-rc2, v2.6.37-rc5 by using .config and spi
patch files from http://elinux.org/BeagleBoard/SPI#Hardware
but both failed to boot........
OMAP3 beagleboard.org # bootm 0x80300000
## Booting kernel from Legacy Image at 80300000 ...
Image Name: Linux-2.6.37-rc2-ben+
Data Size: 3203500 Bytes = 3.1 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
that,s it.......... no response after then.........
I have compile linux-omap-psp-2.6.32 with the spi patch, with the CLK
set to input.
I have also compiled spidev_test
When I run spidev_test on my C4 all I get is zeros, while the CLK and
SIMO pins are always high (~1.8V) in the scope.
Can someone please provide a known good spidev_test executable? I am not
sure I did the crosscompiling correctly.
set to input.
u should do the pin mux settings in u-boot works fine... i dont know
why it fails in kernel.
i dont think that it is problem of spidev_test executable since i
tried successfully through u-boot v2010.09
