Hi all,
I am trying to debug my beagleboard xm using the source of sitara 5.05.
I am following the steps mentioned here:
http://processors.wiki.ti.com/index.php/Sitara_Linux_Training:_uboot_linux_debug_with_ccsv5
However, once I loaded my program and symbols. The program gets stuck on to location 0x14088 and never comes out.
I am not getting the dialog shown for loading program but neither am not getting any output from the console whether my program has loaded or not.
What might be the possible problem?
While the general steps are correct you will need to use the correct addresses and offsets for the processor in the beagleboard rather than the beaglebone/am335x evm/etc.
Hi I have changed the address means I gave it starting from internal RAM address and also tried , text base given in omap3_beagle.h from u-boot.Both are not working. CAn you kindly help me out? thanks!
What is the exact gel file to be added in the project?
Currently I am using am_dm37x_evm gel files. Can this be used with beagleboard xm or something else to be added?
Regards!
What are you trying to debug? U-boot or Linux Kernel? You need to erase all GEL references as u-boot and the Linux kernel configure the hardware so the GEL files will only serve to interfere. Here are some good references on how to debug the Linux kernel.
http://processors.wiki.ti.com/index.php/Category:Code_Composer_Studio_v5
Best way to get started is to boot into the u-boot prompt, setup CCSV5 including loading symbols, setting breakpoints, etc. The boot the kernel by entering boot at the u-boot prompt. You can also follow the CCSV4 instructions which should work on CCSV5:
http://elinux.org/BeagleBoardJTAG
John
Regards!
