SSH login issue
Hi All,
When I got the BBB I changed the root password and I have used it for 2-3 months.
Just 2 weeks ago, i can not login my BBB. I’m sure that I supply the correct password.
But no luck to login. Is there any way to reset the BBB root password? or can I login with another user? Thank you in advance.
Duke
Hi Duke,
If you are using a Unix based system, you can plugin the cable and use the “screen” command and then try to fix the ssh.
