Hello, everyone!
My question is: “Is it possible to perform a SSH connection through UART5?”.
If yes, how to do it?
Thanks!
Hello, everyone!
Thanks!
I’m not sure why you want to do this, but you’ll have a much better time using SSH over ethernet.
I would think the path forward involves:
1.) Getting a TCP stack running over serial instead of Ethernet.
2.) Telling sshd to use your serial-tcp-stack.
Maybe start with this: https://stackoverflow.com/questions/19941357/tcp-ip-over-serial-port
I imagine it’s going to be a lot of hacking together things, but if you can get TCP/IP over serial than you might have some luck.
The other thing that comes to mind is that serial is a point-to-point link, so why not just screen (open normal tty) to bring up a terminal? If you trust the connecting computer and you can physically see the wires connecting to the BBB, I think there is a low chance that your serial comms will be intercepted.
Good luck.
On Wed, 25 Nov 2015 07:13:19 -0800 (PST), Joshua Datko
<jbdatko@gmail.com> declaimed the following:
I'm not sure why you want to do this, but you'll have a much better time
using SSH over ethernet.I would think the path forward involves:
2.) Telling sshd to use your serial-tcp-stack.Maybe start with this:
TCP/IP over Serial Port - Stack OverflowI imagine it's going to be a lot of hacking together things, but if you can
Would SLIRP still be a viable path?
why not just use screen?
