Hi!
I've compiled Angstrom console filesystem. SSH server seems to be
installed but not enabled. How can I enable it? If I use gnome demo
from Koen SSH server is enabled there.
Thanks in advance!
Hi!
Thanks in advance!
On your console image, do a 'opkg list-installed | grep -i ssh' and
see what you get. You may have client (dropbear) but not ssh server.
Brian
dropbear is both client and server
You got me We kind of went through this recently ... had a
requirement for openssh and we had client & no server. Haven't worked
with dorpbear in a while ... good to know it does both!
B
Ssh server is already installed but either not configured or disabled. I even tried to opkg remove and installed the package agian. Anyway trying to connect from a PC gives a message “connection refused”. Did not dig deep and asked here for help.
If you force dropbear to start (just "dropbear" in the command line; it will start as a deamon), does it work?
Systemd is not starting it in my beagle right now, I do not know why. Starting it manually works, though.
To get the status of the dropbear service:
systemctl status dropbear.service
If the dropbear service is not running or not enabled:
systemctl enable dropbear.service
systemctl start dropbear.service
