Hi all,
I am new to BBB. This is a long time haunting problem for me.
For my applications some GUI libraries need to be installed in BBB.
For getting maximum space for installing packages, I am using a 16GB SD card - load the image in SD card and boot from SD card.
If I use the latest debian jessie image bone-debian-8.7-lxqt-4gb-armhf-2017-03-19-4gb.img from https://beagleboard.org/latest-images,
the maximum rootfs size available is only 4GB.
Expanding RootFS for 16GB is not possible with this image.
So as per link https://eewiki.net/display/linuxonarm/BeagleBone+Black#BeagleBoneBlack-SetupmicroSDcard, Bootloader, Kernel and RootFS images are prepared and loaded into the SD card.
But in this procedure the RootFS used is minimal. (obtained from the link -https:``//rcn-ee.com/rootfs/eewiki/minfs/debian-8.7-minimal-armhf-2017-03-02.tar.xz
This minimal image is finely working. ssh through Ethernet port is working fine. But ssh through USB port (Internet through USB) is not working.
openssh-client and openssh-server are already installed.
Is there some more packages to be installed for ssh through USB?
The command ip addr for Ubuntu 16.04 host shows the following messages:
sajeevank@sajeevank-Vostro-3559:~$ ip addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: enp3s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether 28:f1:0e:36:1c:63 brd ff:ff:ff:ff:ff:ff
inet 192.168.2.5/24 brd 192.168.2.255 scope global enp3s0
inet6 fe80::2af1:eff:fe36:1c63/64 scope link
3: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether 1c:ba:8c:a2:ed:72 brd ff:ff:ff:ff:ff:ff
inet 192.168.0.2/24 brd 192.168.0.255 scope global dynamic eth0
valid_lft 83757sec preferred_lft 83757sec
inet6 fe80::9445:1600:d383:baf8/64 scope link
4: wlp2s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
link/ether e4:02:9b:03:8a:90 brd ff:ff:ff:ff:ff:ff
The command ip addr for BBB target shows the following messages:
debian@arm:~$ ip addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
2: eth0: <BROADCAST,MULTICAST,DYNAMIC,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 88:c2:55:96:44:cd brd ff:ff:ff:ff:ff:ff
inet 192.168.2.31/24 brd 192.168.2.255 scope global eth0
inet6 fe80::8ac2:55ff:fe96:44cd/64 scope link
3: usb0: <NO-CARRIER,BROADCAST,MULTICAST,DYNAMIC,UP> mtu 1500 qdisc pfifo_fast master tether state DOWN group default qlen 1000
link/ether 88:c2:55:96:44:cf brd ff:ff:ff:ff:ff:ff
inet 192.168.7.2/30 brd 192.168.7.3 scope global usb0
4: usb1: <BROADCAST,MULTICAST,DYNAMIC,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast master tether state UP group default qlen 1000
link/ether 1c:ba:8c:a2:ed:73 brd ff:ff:ff:ff:ff:ff
inet6 fe80::1eba:8cff:fea2:ed73/64 scope link
5: tether: <BROADCAST,MULTICAST,DYNAMIC,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
inet 192.168.0.1/24 brd 192.168.0.255 scope global tether
inet6 fe80::34f7:7fff:fe2c:50e2/64 scope link
debian@arm:~$
The /etc/networl/interfaces is as follows in Ubuntu Host:
auto lo
iface lo inet loopback
auto enp3s0
iface enp3s0 inet dhcp
The /etc/networl/interfaces is as follows in BBB Target:
auto lo
iface usb0 inet static
address 192.168.7.2
netmask 255.255.255.252
network 192.168.7.0
gateway 192.168.7.1
I can ssh, BBB through Ethernet port now. But my application required this Ethernet port. So my idea is use Ethernet port for Application and USB port for SSH.
So for proceeding with this work,
I need to get either
SSH through USB feature in minimal image
or
expansion capability for latest normal image (expansion to 8GB or 16GB size)
or
availability of a rootfs.tar.gz image which also contains SSH through USB feature
Please help me finding out any one of these.
Thanks in advance for the help.
Thanks & Regards,
Sajeevan.K
