Hello.
I am trying to use custom u-boot that will be run from mmc/sdcard.
For this did next step:
- clone it:
git clone git://git.denx.de/u-boot.git u-boot/
- checkout to new version:
git checkout v2017.11
2. configure it:
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- am335x_boneblack_defconfig
3. build it:
- than copy MLO and u-boot.img to mmc:
cp MLO u-boot.img /media/inisider/boot/
- insert microsd to beagleboneblack slot than press ButtonSwitch (S2) and poweron BBB:
U-Boot 2017.09-00002-g0f3f1c7907 (Oct 09 2017 - 15:30:22 -0500), Build: jenkins-github_Bootloader-Builder-607
CPU : AM335X-GP rev 2.1
I2C: ready
DRAM: 512 MiB
No match for driver ‘omap_hsmmc’
Some drivers were not found
Using default environmentBoard: BeagleBone Black
not set. Validating first E-fuse MAC
BeagleBone Black:
BeagleBone: cape eeprom: i2c_probe: 0x54:
BeagleBone: cape eeprom: i2c_probe: 0x55:
BeagleBone: cape eeprom: i2c_probe: 0x56:
BeagleBone: cape eeprom: i2c_probe: 0x57:
Net: eth0: MII MODE
cpsw
Press SPACE to abort autoboot in 2 seconds
Information about my microsdcard:
sudo fdisk /dev/sdc
Command (m for help): p
Disk /dev/sdc: 7744 MB, 7744782336 bytes
239 heads, 62 sectors/track, 1020 cylinders, total 15126528 sectors
Units = sectors of 1 * 512 = 512 bytes
Disk identifier: 0x00053946Device Boot Start End Blocks Id System
/dev/sdc1 2048 206847 102400 b W95 FAT32
/dev/sdc2 206848 2254847 1024000 83 Linux
This is not compiled by me U-boot.
What can be a problem?
