I have to BB xM, both were working fine. but recently I started to get
60BE on one of the boards.
tried with another sdcard (which works definitely), but sill getting
the same 60BE. also, the chips
are getting warm on this board. any ideas?
thanks
It depends on the definition of warm. They always get warm. Now your board may or may not be warmer than normal. That message indicates that the board cannot read the SD card. That could be related to a power issue on the board or a damaged connector.
just compared both again .. D5 is on all the time (when power is
connected),
D13 and D14 are on for a second then turn off
thanks
I was referring to the power output from the TPS65950 to the SD card slot. You can measure and see if it is getting the 3V during boot up.
ah. so, on few sdcard's connects I see 3.03V, couple of them goes up-
down all the time.
TPS65950 is getting rather hot in few seconds, so I turned the thing
off.
probably I forgot to press send button, so repeat ...
down all the time.
off.
I would request an RMA and have it looked at.
http://beagleboard.org/support/rma
ok, thanks, gonna proceed what you suggested ...
