Steady Boot screen in u-boot/Linux No transition
Hello list,
I’m using a BBB with a Chipsee 7’’ LCD display from :
https://www.tigal.com/product/3526
I want to have a steady Boot/Splash screen right from the board Startup untill my Qt/UI application run.
So far I modified succesfully u-boot sources (version 2014.10) to include a Boot logo following the instruction here :
http://e2e.ti.com/support/arm/sitara_arm/f/791/p/217383/952703
I also modified the default Tux Logo included in the Linux Kernel (https://github.com/beagleboard/linux) to replace it with mine (same as used in u-boot).
my goal is to achieve that the user does not notice this transition bewteen bootloader and kernel logo, in the fact the kernel is probably during the lcd initialization clearing the u-boot logo and displaying the kernel boot logo (after a certain time).
can someone share if have similar experience ?
Thank you.
Dear Ayoub,
May I ask you if you found a solution ?
I found something that could help at http://www.denx.de/wiki/view/DULG/LinuxSplashScreen
best regards,
julien
