still getting lockups on OTG USB
I thought i was rid of these, but i had another lockup of the OTG port
on my C3 beagleboard. i am now running an ubuntu lucid image built
today, kernel 2.6.32.11-l12. the board is connected to a USB-ethernet
and hardisk through a USB hub on the OTG port (the other USB port was
even more unreliable).
the lockup seems to only occur when the beagleboard is doing something
intensive. today when a rtorrent was checksumming some large files. in
the past i have triggered it by rsync files around the USB hard disk,
or over the network.
[21143.561828] musb_ep_program 832: broken !rx_reinit, ep3 csr 0003
[21143.568176] musb_ep_program 832: broken !rx_reinit, ep3 csr 0203
[21143.574432] musb_ep_program 832: broken !rx_reinit, ep3 csr 0003
[21143.580688] musb_ep_program 832: broken !rx_reinit, ep3 csr 0203
[21143.586944] musb_ep_program 832: broken !rx_reinit, ep3 csr 0003
[21143.593200] musb_ep_program 832: broken !rx_reinit, ep3 csr 0203
[21143.599456] musb_ep_program 832: broken !rx_reinit, ep3 csr 0003
[21143.605712] musb_ep_program 832: broken !rx_reinit, ep3 csr 0203
[21143.694793] usb 2-1.4.4: reset high speed USB device using
musb_hdrc and address 5
[21153.890258] usb 2-1.4.4: reset high speed USB device using
[21170.085418] usb 2-1.4.4: reset high speed USB device using
[21170.280914] usb 2-1.4.4: reset high speed USB device using
[21180.476226] usb 2-1.4.4: reset high speed USB device using
[21180.586029] sd 0:0:0:0: Device offlined - not ready after error
recovery
[21180.586090] sd 0:0:0:0: [sda] Unhandled error code
[21180.586090] sd 0:0:0:0: [sda] Result: hostbyte=0x05 driverbyte=0x00
[21180.586120] sd 0:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 13 d4 c7 1a
00 00 f0 00
[21180.586181] end_request: I/O error, dev sda, sector 332711706
[21180.592376] sd 0:0:0:0: rejecting I/O to offline device
[21181.146209] sd 0:0:0:0: rejecting I/O to offline device
[21181.152770] sd 0:0:0:0: [sda] Unhandled error code
[21181.152770] sd 0:0:0:0: [sda] Result: hostbyte=0x01 driverbyte=0x00
[21181.152801] sd 0:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 13 d4 c8 0a
00 00 20 00
[21181.152862] end_request: I/O error, dev sda, sector 332711946
[21187.561676] ------------[ cut here ]------------
[21187.561737] WARNING: at net/sched/sch_generic.c:261 dev_watchdog
+0x17c/0x280()
[21187.561767] NETDEV WATCHDOG: eth0 (dm9601): transmit queue 0 timed
out
[21187.561767] Modules linked in: dm9601 usbnet mailbox_mach
rtc_twl4030 mailbox rtc_core
[21187.561828] Backtrace:
[21187.561859] [<c003a744>] (dump_backtrace+0x0/0x110) from
[<c04c8300>] (dump_stack+0x18/0x1c)
[21187.561889] r6:00000105 r5:c03e638c r4:c061ddf8 r3:00000002
[21187.561950] [<c04c82e8>] (dump_stack+0x0/0x1c) from [<c005b878>]
(warn_slowpath_common+0x50/0x68)
[21187.561981] [<c005b828>] (warn_slowpath_common+0x0/0x68) from
[<c005b8dc>] (warn_slowpath_fmt+0x30/0x38)
[21187.562011] r7:00000001 r6:c06aacec r5:00000000 r4:cfafe800
[21187.562072] [<c005b8ac>] (warn_slowpath_fmt+0x0/0x38) from
[<c03e638c>] (dev_watchdog+0x17c/0x280)
[21187.562103] r3:cfafe800 r2:c05ed30b
[21187.562133] [<c03e6210>] (dev_watchdog+0x0/0x280) from [<c0065c28>]
(run_timer_softirq+0x1a8/0x258)
[21187.562164] [<c0065a80>] (run_timer_softirq+0x0/0x258) from
[<c006133c>] (__do_softirq+0x8c/0x11c)
[21187.562194] [<c00612b0>] (__do_softirq+0x0/0x11c) from [<c006141c>]
(irq_exit+0x50/0xa4)
[21187.562255] [<c00613cc>] (irq_exit+0x0/0xa4) from [<c0036078>]
(asm_do_IRQ+0x78/0x90)
[21187.562286] [<c0036000>] (asm_do_IRQ+0x0/0x90) from [<c0036ac4>]
(__irq_svc+0x44/0xa8)
[21187.562316] Exception stack(0xc061df48 to 0xc061df90)
[21187.562316] df40: 00000000 00000000 80000013
c0661280 c061c000 c061fe70
[21187.562377] df60: c061fd10 c0660904 8002d794 411fc083 0000001f
c061df9c c061df90 c061df90
[21187.562377] df80: c0045ef0 c0045f28 60000013 ffffffff
[21187.562408] r5:fa200000 r4:ffffffff
[21187.562438] [<c0045ed8>] (omap3_pm_idle+0x0/0x54) from [<c003801c>]
(cpu_idle+0x60/0xc0)
[21187.562500] [<c0037fbc>] (cpu_idle+0x0/0xc0) from [<c04c395c>]
(rest_init+0x70/0x84)
[21187.562500] r7:c061fd08 r6:c002fe14 r5:c002fe18 r4:c0693dfc
[21187.562561] [<c04c38ec>] (rest_init+0x0/0x84) from [<c00089ac>]
(start_kernel+0x270/0x2c8)
[21187.562591] [<c000873c>] (start_kernel+0x0/0x2c8) from [<80008034>]
(0x80008034)
[21187.562622] ---[ end trace 3f17a9538ab7c924 ]---
once the lockup has happened i can no longer access the USB disk or
the network.
do you think that my board might be defective?
sam
Hey Sam,
Some of these usb pata/sata controllers are hit an miss as for
reliability.. Which one are you using? (lsusb / lsmod)
I think i've fixed more with:
http://rcn-ee.net/deb/kernel/beagle/lucid/v2.6.33.2-dl6/
But i still have one that seems to corrupts no matter what..
[122911.481018] usb 2-1.2: Product: USB to ATA/ATAPI Bridge
[122911.486816] usb 2-1.2: Manufacturer: JMicron
[122911.491729] usb 2-1.2: SerialNumber: D57CA7973218
its one of the recent WD portable 2.5" hard disks. i believe the USB
port is on the HD main board, so there is no USB->SATA chipset (unless
thats on the mainboard to).
sam@beagleboard:~$ lsusb
Bus 002 Device 005: ID 1058:1010 Western Digital Technologies, Inc.
Bus 002 Device 004: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port
HUB
Bus 002 Device 003: ID 0a46:9601 Davicom Semiconductor, Inc. DM9601
Fast Ethernet Adapter
Bus 002 Device 002: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port
HUB
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
sam@beagleboard:~$ lsmod
Module Size Used by
dm9601 5404 0
usbnet 11554 1 dm9601
rtc_twl4030 4139 0
mailbox_mach 4135 0
mailbox 3321 1 mailbox_mach
rtc_core 11715 1 rtc_twl4030
the install me for http://rcn-ee.net/deb/kernel/beagle/lucid/v2.6.33.2-dl6/
gives me the following error
awk: 1: unexpected character '\'
from the line
awk '{print \x243}'
sam
Crap, that's sup post to be "\#3" 0x24 = # the install-me.sh's are
auto generated..
I commented my way past the awk error, and have installed the new
kernel. i'll see how that goes.
thanks
sam
Same lockup with the v2.6.33.2-dl6 kernel. :frowning:
Sam
