Thanks for the reply,
In order to make the kernel works, I changed all the boot command line
in the menuconfig.
I flashed the filesystem onto the NAND with u-boot
Here the link of how I did :
http://elinux.org/BeagleBoardNAND
and this is my log :
Booting from nand ...
NAND read: device 0 offset 0x280000, size 0x400000
4194304 bytes read: OK
## Booting kernel from Legacy Image at 82000000 ...
Image Name: Linux-2.6.32
Data Size: 2618424 Bytes = 2.5 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing
Linux...................................................................................................................................................................
done, booting the kernel.
Linux version 2.6.32 (thibault@cafeier) (gcc version 4.4.0 (GCC) ) #2
Fri Aug 5 10:39:12 CEST 2011
CPU: ARMv7 Processor [411fc083] revision 3 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Machine: OMAP3 Beagle Board
Memory policy: ECC disabled, Data cache writeback
OMAP3430/3530 ES3.1 (l2cache iva sgx neon isp 720m )
SRAM: Mapped pa 0x40200000 to va 0xfe400000 size: 0x100000
Reserving 12582912 bytes SDRAM for VRAM
Built 1 zonelists in Zone order, mobility grouping on. Total pages:
65024
Kernel command line: console=ttyS2,115200n8 mpurate=720 vram=12M
omapfb.mode=dvi:1024x768MR-16@60 omapdss.def_disp=dvi root=mtd4
rootfstype=jffs2
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 128MB 128MB = 256MB total
Memory: 241664KB available (4532K code, 825K data, 172K init, 0K
highmem)
Hierarchical RCU implementation.
NR_IRQS:402
Clocking rate (Crystal/Core/MPU): 26.0/332/500 MHz
Reprogramming SDRC clock to 332000000 Hz
GPMC revision 5.0
IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96 interrupts
Total of 96 interrupts on 1 active controller
OMAP GPIO hardware version 2.5
OMAP clockevent source: GPTIMER12 at 32768 Hz
Console: colour dummy device 80x30
Calibrating delay loop... 487.36 BogoMIPS (lpj=1904640)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
regulator: core version 0.5
NET: Registered protocol family 16
Found NAND on CS0
Registering NAND on CS0
Unable to get DVI reset GPIO
Target VDD1 OPP = 6, VDD2 OPP = 3
OMAP DMA hardware revision 4.0
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
i2c_omap i2c_omap.1: bus 1 rev3.12 at 2600 kHz
twl4030: PIH (irq 7) chaining IRQs 368..375
twl4030: power (irq 373) chaining IRQs 376..383
twl4030: gpio (irq 368) chaining IRQs 384..401
regulator: VUSB1V5: 1500 mV normal standby
regulator: VUSB1V8: 1800 mV normal standby
regulator: VUSB3V1: 3100 mV normal standby
twl4030_usb twl4030_usb: Initialized TWL4030 USB module
regulator: VMMC1: 1850 <--> 3150 mV normal standby
regulator: VDAC: 1800 mV normal standby
regulator: VPLL2: 1800 mV normal standby
regulator: VSIM: 1800 <--> 3000 mV normal standby
regulator: VAUX3: 1800 mV normal standby
regulator: VAUX4: 1800 mV normal standby
i2c_omap i2c_omap.2: bus 2 rev3.12 at 100 kHz
i2c_omap i2c_omap.3: bus 3 rev3.12 at 100 kHz
Switching to clocksource 32k_counter
musb_hdrc: version 6.0, musb-dma, otg (peripheral+host), debug=0
musb_hdrc: USB OTG mode controller at fa0ab000 using DMA, IRQ 92
NET: Registered protocol family 2
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
omap-iommu omap-iommu.0: isp registered
NetWinder Floating Point Emulator V0.97 (double precision)
ashmem: initialized
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
yaffs Aug 4 2011 18:00:31 Installing.
msgmni has been set to 472
alg: No test for stdrng (krng)
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
OMAP DSS rev 2.0
OMAP DISPC rev 3.0
OMAP VENC rev 2
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a ST16654
serial8250.1: ttyS1 at MMIO 0x4806c000 (irq = 73) is a ST16654
serial8250.2: ttyS2 at MMIO 0x49020000 (irq = 74) is a ST16654
console [ttyS2] enabled
brd: module loaded
loop: module loaded
usbcore: registered new interface driver asix
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver cdc_eem
usbcore: registered new interface driver dm9601
usbcore: registered new interface driver smsc95xx
usbcore: registered new interface driver gl620a
usbcore: registered new interface driver net1080
usbcore: registered new interface driver plusb
usbcore: registered new interface driver rndis_host
usbcore: registered new interface driver cdc_subset
usbcore: registered new interface driver zaurus
usbcore: registered new interface driver MOSCHIP usb-ethernet driver
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 3 ports detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
android init
android_probe pdata: c04d153c
android_bind
android_usb gadget: android_usb ready
musb_hdrc musb_hdrc: MUSB HDRC host driver
musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 2
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
f_adb init
android_register_function adb
adb_bind_config
f_mass_storage init
android_register_function usb_mass_storage
mice: PS/2 mouse device common for all mice
input: gpio-keys as /devices/platform/gpio-keys/input/input0
i2c /dev entries driver
Linux video capture interface: v2.00
omap-iommu omap-iommu.0: isp: version 1.1
OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
mmci-omap-hs mmci-omap-hs.1: err -16 configuring card detect
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
logger: created 64K log 'log_main'
logger: created 256K log 'log_events'
logger: created 64K log 'log_radio'
logger: created 64K log 'log_system'
Advanced Linux Sound Architecture Driver Version 1.0.21.
usbcore: registered new interface driver snd-usb-audio
usb 1-2: new high speed USB device using ehci-omap and address 2
No device for DAI omap-mcbsp-dai-0
No device for DAI omap-mcbsp-dai-1
No device for DAI omap-mcbsp-dai-2
No device for DAI omap-mcbsp-dai-3
No device for DAI omap-mcbsp-dai-4
OMAP3 Beagle SoC init
asoc: twl4030 <-> omap-mcbsp-dai-0 mapping ok
ALSA device list:
#0: omap3beagle (twl4030)
TCP cubic registered
NET: Registered protocol family 17
NET: Registered protocol family 15
Power Management for TI OMAP3.
------------[ cut here ]------------
WARNING: at arch/arm/mach-omap2/dpll.c:439 omap3_noncore_dpll_set_rate
+0x220/0x264()
Modules linked in:
[<c00399d8>] (unwind_backtrace+0x0/0xd8) from [<c005f8a0>]
(warn_slowpath_common+0x48/0x60)
[<c005f8a0>] (warn_slowpath_common+0x48/0x60) from [<c0043910>]
(omap3_noncore_dpll_set_rate+0x220/0x264)
[<c0043910>] (omap3_noncore_dpll_set_rate+0x220/0x264) from
[<c0041f20>] (omap2_clk_set_rate+0x20/0x2c)
[<c0041f20>] (omap2_clk_set_rate+0x20/0x2c) from [<c004887c>]
(clk_set_rate+0x38/0x88)
[<c004887c>] (clk_set_rate+0x38/0x88) from [<c00103f0>]
(omap2_clk_set_freq+0x270/0x408)
[<c00103f0>] (omap2_clk_set_freq+0x270/0x408) from [<c000fd6c>]
(omap3_sr_init+0xd4/0x154)
[<c000fd6c>] (omap3_sr_init+0xd4/0x154) from [<c0033344>]
(do_one_initcall+0x5c/0x1b4)
[<c0033344>] (do_one_initcall+0x5c/0x1b4) from [<c0008578>]
(kernel_init+0x98/0x110)
[<c0008578>] (kernel_init+0x98/0x110) from [<c0034ecc>]
(kernel_thread_exit+0x0/0x8)
---[ end trace 1e983701b8aa800f ]---
Switched to new clocking rate (Crystal/Core/MPU): 26.0/332/720 MHz
IVA2 clocking rate: 520 MHz
SmartReflex driver initialized
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev
1
fbcvt: 1024x768@60: CVT Name - .786M3-R
regulator_init_complete: incomplete constraints, leaving VAUX3 on
regulator_init_complete: incomplete constraints, leaving VDVI on
regulator_init_complete: incomplete constraints, leaving VDAC on
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
omapdss DPI error: display already enabled
omap_vout omap_vout: 'dvi' Display already enabled
omap_vout omap_vout: Buffer Size = 3686400
omap_vout omap_vout: : registered and initialized video device 0
omap_vout omap_vout: : registered and initialized video device 1
VFS: Cannot open root device "mtd4" or unknown-block(0,0)
Please append a correct "root=" boot option; here are the available
partitions:
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-
block(0,0)
