Hello.
I have BB rev C3, kingston mSD 8GB class 10
First, i prepared SD card
http://elinux.org/BeagleBoardDebian#Debian_.28jessie.29
sudo ./setup_sdcard.sh --mmc /dev/sdb --dtb omap3-beagle
Second, i upgraded uboot
http://elinux.org/BeagleBoardNAND#U-Boot_v2011.12_or_newer
Then i try to boot, stop booting by Load Ramdisk. No HDMI output.
Help me with booting, please.
Console log:
U-Boot SPL 2016.03-00001-g54456ef (Mar 17 2016 - 16:31:02)
Trying to boot from NAND
SPL: Please implement spl_start_uboot() for your board
SPL: Direct Linux boot not active!
U-Boot 2016.03-00001-g54456ef (Mar 17 2016 - 16:31:02 -0500), Build: jenkins-github_Bootloader-Builder-351
OMAP3530-GP ES3.0, CPU-OPP2, L3-165MHz, Max CPU Clock 600 MHz
I2C: ready
DRAM: 256 MiB
NAND: 256 MiB
MMC: OMAP SD/MMC: 0
*** Warning - bad CRC, using default environment
Beagle Rev C1/C2/C3
Timed out in wait_for_event: status=1000
Check if pads/pull-ups of bus 1 are properly configured
No EEPROM on expansion board
Timed out in wait_for_bb: status=1000
OMAP die ID: 0400d01304013f790000000037240003
Net: usb_ether
Error: usb_ether address not set.
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Checking for: /uEnv.txt …
Checking for: /boot/uEnv.txt …
295 bytes read in 40 ms (6.8 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt…
Running uname_boot …
loading /boot/vmlinuz-4.5.0-armv7-x2 …
5878216 bytes read in 473 ms (11.9 MiB/s)
loading /boot/dtbs/4.5.0-armv7-x2/omap3-beagle.dtb …
107183 bytes read in 421 ms (248 KiB/s)
loading /boot/initrd.img-4.5.0-armv7-x2 …
10403546 bytes read in 811 ms (12.2 MiB/s)
debug: [console=ttyO2,115200n8 root=UUID=26e687b2-0078-49b2-901f-5124edf835c3 ro rootfstype=ext4 rootwait musb_hdrc.fifo_mode=5 coherent_pool=1M quiet] …
debug: [bootz 0x82000000 0x88080000:9ebeda 0x88000000] …
Kernel image @ 0x82000000 [ 0x000000 - 0x59b1c8 ]
Loading Ramdisk to 8f614000, end 8ffffeda …
Environments:
arch=arm
args_mmc=run finduuid;setenv bootargs console=${console} ${optargs} root=PARTUUID=${uuid} ro rootfstype=${mmcrootfstype} ${musb} ${cmdline}
args_mmc_old=setenv bootargs console=${console} ${optargs} root=${oldroot} ro rootfstype=${mmcrootfstype} ${musb} ${cmdline}
args_mmc_uuid=setenv bootargs console=${console} ${optargs} root=UUID=${uuid} ro rootfstype=${mmcrootfstype} ${musb} ${cmdline}
args_netinstall=setenv bootargs ${netinstall_bootargs} ${optargs} ${cape_disable} ${cape_enable} root=/dev/ram rw ${musb} ${cmdline}
args_uenv_root=setenv bootargs console=${console} ${optargs} root=${uenv_root} ro rootfstype=${mmcrootfstype} ${musb} ${cmdline}
baudrate=115200
beaglerev=Cx
board=beagle
board_name=beagle
boot=${interface} dev ${mmcdev}; if ${interface} rescan; then echo SD/MMC found on device ${mmcdev};setenv bootpart ${mmcdev}:1; echo Checking for: /uEnv.txt …;if test -e ${interface} ${bootpart} /uEnv.txt; then load ${interface} ${bootpart} ${loadaddr} /uEnv.txt;env import -t ${loadaddr} ${filesize};echo Loaded environment from /uEnv.txt;echo Checking if uenvcmd is set …;if test -n ${uenvcmd}; then echo Running uenvcmd …;run uenvcmd;fi;fi; echo Checking for: /boot/uEnv.txt …;for i in 1 2 3 4 5 6 7 ; do setenv mmcpart ${i};setenv bootpart ${mmcdev}:${mmcpart};if test -e ${interface} ${bootpart} /boot/uEnv.txt; then load ${interface} ${bootpart} ${loadaddr} /boot/uEnv.txt;env import -t ${loadaddr} ${filesize};echo Loaded environment from /boot/uEnv.txt;if test -n ${dtb}; then setenv fdtfile ${dtb};echo Using: dtb=${fdtfile} …;fi;echo Checking if uname_r is set in /boot/uEnv.txt…;if test -n ${uname_r}; then setenv oldroot /dev/mmcblk${mmcblk}p${mmcpart};echo Running uname_boot …;run uname_boot;fi;fi;done;fi;
bootcmd=run findfdt; setenv interface mmc; setenv mmcblk 0; setenv mmcdev 0; run boot;
bootdelay=1
bootdir=/boot
bootenv=uEnv.txt
bootfile=zImage
bootm_size=0x10000000
bootpart=0:2
bootscript=echo Running bootscript from mmc${mmcdev} …; source ${loadaddr}
buddy=none
buddy2=none
cpu=armv7
ethact=usb_ether
fdt_addr_r=0x88000000
fdtaddr=0x88000000
fdtfile=undefined
findfdt=if test $beaglerev = AxBx; then setenv fdtfile omap3-beagle.dtb; fi; if test $beaglerev = Cx; then setenv fdtfile omap3-beagle.dtb; fi; if test $beaglerev = C4; then setenv fdtfile omap3-beagle.dtb; fi; if test $beaglerev = xMAB; then setenv fdtfile omap3-beagle-xm-ab.dtb; fi; if test $beaglerev = xMC; then setenv fdtfile omap3-beagle-xm.dtb; fi; if test $fdtfile = undefined; then echo WARNING: Could not determine device tree to use; fi;
finduuid=part uuid ${interface} ${bootpart} uuid
importbootenv=echo Importing environment from mmc${mmcdev} …; env import -t ${loadaddr} ${filesize}
kernel_addr_r=0x82000000
loadaddr=0x82000000
loadbootenv=load ${interface} ${bootpart} ${loadaddr} ${bootenv}
loadbootscript=load ${interface} ${mmcdev} ${loadaddr} boot.scr
loadfdt=echo loading ${fdtdir}/${fdtfile} …; load ${interface} ${bootpart} ${fdtaddr} ${fdtdir}/${fdtfile}
loadimage=load ${interface} ${bootpart} ${loadaddr} ${bootdir}/${bootfile}
loadrd=load ${interface} ${bootpart} ${rdaddr} ${bootdir}/${rdfile}; setenv rdsize ${filesize}
loaduimage=load ${interface} ${mmcdev} ${loadaddr} uImage
mmcboot=echo Booting from mmc${mmcdev} …; run args_mmc; bootz ${loadaddr} - ${fdtaddr}
mmcdev=0
mmcrootfstype=ext4 rootwait
musb=musb_hdrc.fifo_mode=5
pxefile_addr_r=0x80100000
ramdisk_addr_r=0x88080000
rdaddr=0x88080000
scriptaddr=0x80000000
soc=omap3
stderr=ns16550_serial
stdin=ns16550_serial
stdout=ns16550_serial
uimageboot=echo Booting from mmc${mmcdev} …; run args_mmc; bootm ${loadaddr}
uname_boot=setenv bootdir /boot; setenv bootfile vmlinuz-${uname_r}; if test -e ${interface} ${bootpart} ${bootdir}/${bootfile}; then echo loading ${bootdir}/${bootfile} …; run loadimage;setenv fdtdir /boot/dtbs/${uname_r}; if test -e ${interface} ${bootpart} ${fdtdir}/${fdtfile}; then run loadfdt;else setenv fdtdir /usr/lib/linux-image-${uname_r}; if test -e ${interface} ${bootpart} ${fdtdir}/${fdtfile}; then run loadfdt;else setenv fdtdir /lib/firmware/${uname_r}/device-tree; if test -e ${interface} ${bootpart} ${fdtdir}/${fdtfile}; then run loadfdt;else setenv fdtdir /boot/dtb-${uname_r}; if test -e ${interface} ${bootpart} ${fdtdir}/${fdtfile}; then run loadfdt;else setenv fdtdir /boot/dtbs; if test -e ${interface} ${bootpart} ${fdtdir}/${fdtfile}; then run loadfdt;else setenv fdtdir /boot/dtb; if test -e ${interface} ${bootpart} ${fdtdir}/${fdtfile}; then run loadfdt;else setenv fdtdir /boot; if test -e ${interface} ${bootpart} ${fdtdir}/${fdtfile}; then run loadfdt;else echo; echo unable to find ${fdtfile} …; echo booting legacy …;run args_mmc;echo debug: [${bootargs}] … ;echo debug: [bootz ${loadaddr}] … ;bootz ${loadaddr}; fi;fi;fi;fi;fi;fi;fi; setenv rdfile initrd.img-${uname_r}; if test -e ${interface} ${bootpart} ${bootdir}/${rdfile}; then echo loading ${bootdir}/${rdfile} …; run loadrd;if test -n ${netinstall_enable}; then run args_netinstall; run message;echo debug: [${bootargs}] … ;echo debug: [bootz ${loadaddr} ${rdaddr}:${rdsize} ${fdtaddr}] … ;bootz ${loadaddr} ${rdaddr}:${rdsize} ${fdtaddr}; fi;if test -n ${uenv_root}; then run args_uenv_root;echo debug: [${bootargs}] … ;echo debug: [bootz ${loadaddr} ${rdaddr}:${rdsize} ${fdtaddr}] … ;bootz ${loadaddr} ${rdaddr}:${rdsize} ${fdtaddr}; fi;if test -n ${uuid}; then run args_mmc_uuid;echo debug: [${bootargs}] … ;echo debug: [bootz ${loadaddr} ${rdaddr}:${rdsize} ${fdtaddr}] … ;bootz ${loadaddr} ${rdaddr}:${rdsize} ${fdtaddr}; else run args_mmc_old;echo debug: [${bootargs}] … ;echo debug: [bootz ${loadaddr} ${rdaddr}:${rdsize} ${fdtaddr}] … ;bootz ${loadaddr} ${rdaddr}:${rdsize} ${fdtaddr}; fi;else if test -n ${uenv_root}; then run args_uenv_root;echo debug: [${bootargs}] … ;echo debug: [bootz ${loadaddr} - ${fdtaddr}] … ;bootz ${loadaddr} - ${fdtaddr}; fi;run args_mmc_old;echo debug: [${bootargs}] … ;echo debug: [bootz ${loadaddr} - ${fdtaddr}] … ;bootz ${loadaddr} - ${fdtaddr}; fi;fi;
usbtty=cdc_acm
vendor=ti
ver=U-Boot 2016.03-00001-g54456ef (Mar 17 2016 - 16:31:02 -0500)
vram=16M
Environment size: 6302/131068 bytes
