Stop Here [ 3.821258] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. )
I wonder If someone could help me with this problem. when i boot the
board, it stopped booting here [ 3.821258] EXT4-fs (mmcblk0p2):
mounted filesystem with ordered data mode. ) . is there something
wrong with the sd card?
thanks.
Welcome to minicom 2.4
OPTIONS: I18n
Compiled on Jun 3 2010, 13:46:31.
Port /dev/ttyUSB0
Press CTRL-A Z for help on special keys
Texas Instruments X-Loader 1.4.4ss (Sep 22 2010 - 16:12:19)
Beagle xM Rev A
Reading boot sector
Loading u-boot.bin from mmc
U-Boot 2010.03-dirty (Oct 18 2010 - 11:31:58)
OMAP3630/3730-GP ES2.0, CPU-OPP2, L3-165MHz,
I2C: ready
DRAM: 512 MB
NAND: 0
MiB
*** Warning - bad CRC or NAND, using default
environment
In:
serial
Out:
serial
Err:
serial
Probing for expansion boards, if none are connected you'll see a
harmless I2C e.
No EEPROM on expansion
board
Beagle xM Rev
A
Die ID
#274800011ff00000015739eb0a009027
Hit any key to stop autoboot:
0
mmc1 is
available
The user button is currently NOT
pressed.
reading
boot.scr
679 bytes
read
Running bootscript from
mmc ...
## Executing script at
80200000
Debug: Demo Image
Install
Kernel is not ready for 1Ghz limiting to
800Mhz
mmc1 is
available
reading
uImage
4431548 bytes
read
reading
uInitrd
3942612 bytes
read
## Booting kernel from Legacy Image at
80300000 ...
   Image Name: 2.6.35.8-
l7
   Image Type: ARM Linux Kernel Image
(uncompressed)
   Data Size: 4431484 Bytes = 4.2
MB
   Load Address:
80008000
   Entry Point:
80008000
   Verifying Checksum ...
OK
## Loading init Ramdisk from Legacy Image at
81600000 ...
   Image Name:
initramfs
   Image Type: ARM Linux RAMDisk Image
(uncompressed)
   Data Size: 3942548 Bytes = 3.8
MB
   Load Address:
00000000
   Entry Point:
00000000
OK
   Loading Kernel Image ...
OK
OK
Starting
kernel ...
Uncompressing Linux... done, booting the
kernel.
[ 0.000000] Initializing cgroup subsys
cpuset
cpu
[ 0.000000] Linux version 2.6.35.8-l7 (root@beagle-256mb-0) (gcc
version 4.40
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7),
cr=10c53c7f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT nonaliasing
instruction ce
[ 0.000000] Machine: OMAP3 Beagle
Board
[ 0.000000] Beagle expansionboard:
none
[ 0.000000] Memory policy: ECC disabled, Data cache
writeback
[ 0.000000] OMAP3630 ES1.0 (l2cache iva sgx neon isp
192mhz_clk )
[ 0.000000] SRAM: Mapped pa 0x40200000 to va 0xfe400000 size:
0x100000
[ 0.000000] Reserving 12582912 bytes SDRAM for
VRAM
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on.
Total pa8
[ 0.000000] Kernel command line: console=ttyS2,115200n8
console=tty0 root=/d0
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192
bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6,
262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072
bytes)
[ 0.000000] allocated 2621440 bytes of
page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't
want memos
[ 0.000000] Memory: 256MB 256MB = 512MB
total
[ 0.000000] Memory: 485236k/485236k available, 39052k reserved, 0K
highmem
[ 0.000000] Virtual kernel memory
layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4
kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896
kB)
[ 0.000000] DMA : 0xffc00000 - 0xffe00000 ( 2
MB)
[ 0.000000] vmalloc : 0xe0800000 - 0xf8000000 ( 376
MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512
MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16
MB)
[ 0.000000] .init : 0xc0008000 - 0xc004a000 ( 264
kB)
[ 0.000000] .text : 0xc004a000 - 0xc07f6000 (7856
kB)
[ 0.000000] .data : 0xc0864000 - 0xc08c3960 ( 383
kB)
[ 0.000000] SLUB: Genslabs=9, HWalign=64, Order=0-3, MinObjects=0,
CPUs=1, N1
[ 0.000000] Hierarchical RCU
implementation.
[ 0.000000] RCU-based detection of stalled CPUs is
disabled.
[ 0.000000] Verbose stalled-CPUs detection is
disabled.
[ 0.000000] NR_IRQS:
402
[ 0.000000] Clocking rate (Crystal/Core/MPU): 26.0/332/600
MHz
[ 0.000000] (null): no physical address for uart#3, so skipping
early_init..
[ 0.000000] omap_hwmod: l3_hwmod: cannot be enabled
(3)
[ 0.000000] omap_hwmod: l4_core_hwmod: cannot be enabled
(3)
[ 0.000000] omap_hwmod: l4_per_hwmod: cannot be enabled
(3)
[ 0.000000] omap_hwmod: l4_wkup_hwmod: cannot be enabled
(3)
[ 0.000000] Reprogramming SDRC clock to 332000000
Hz
[ 0.000000] GPMC revision
5.0
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96
interrups
[ 0.000000] Total of 96 interrupts on 1 active
controller
[ 0.000000] OMAP GPIO hardware version
2.5
[ 0.000000] OMAP clockevent source: GPTIMER12 at 32768
Hz
[ 0.000000] Console: colour dummy device
80x30
[ 0.000000] console [tty0]
enabled
[ 0.000000] Calibrating delay loop... 500.97 BogoMIPS
(lpj=1953792)
[ 0.000000] pid_max: default: 32768 minimum:
301
[ 0.000000] Security Framework
initialized
[ 0.000000] Smack:
Initializing.
[ 0.000000] Mount-cache hash table entries:
512
ns
cpuacct
memory
devices
freezer
[ 0.000000] CPU: Testing write buffer coherency:
ok
[ 0.000000] devtmpfs:
initialized
[ 0.000000] regulator: core version
0.5
[ 0.000000] NET: Registered protocol family
16
[ 0.000000] OMAP3 Beagle Rev: xM
A
[ 0.000000] ------------[ cut
here ]------------
[ 0.000000] WARNING: at arch/arm/mach-omap2/serial.c:727
omap_serial_init_po)
[ 0.000000] (null): can't init uart3, no clocks
available
[ 0.000000] Modules linked
in:
[ 0.000000] [<c00512a0>] (unwind_backtrace+0x0/0x100) from
[<c06386f0>] (dum)
[ 0.000000] [<c06386f0>] (dump_stack+0x18/0x1c) from [<c0085818>]
(warn_slow)
[ 0.000000] [<c0085818>] (warn_slowpath_common+0x5c/0x6c) from
[<c00858cc>] )
[ 0.000000] [<c00858cc>] (warn_slowpath_fmt+0x38/0x40) from
[<c00110a4>] (om)
[ 0.000000] [<c00110a4>] (omap_serial_init_port+0x90/0x368) from
[<c00113ac>)
[ 0.000000] [<c00113ac>] (omap_serial_init+0x30/0x3c) from
[<c0013428>] (oma)
[ 0.000000] [<c0013428>] (omap3_beagle_init+0x26c/0x4e8) from
[<c000c7c0>] ()
[ 0.000000] [<c000c7c0>] (customize_machine+0x24/0x2c) from
[<c004a3f4>] (do)
[ 0.000000] [<c004a3f4>] (do_one_initcall+0x3c/0x1dc) from
[<c0008678>] (ker)
[ 0.000000] [<c0008678>] (kernel_init+0x128/0x1b8) from
[<c004b52c>] (kernel)
[ 0.000000] ---[ end trace
1b75b31a2719ed1c ]---
[ 0.000000] Found NAND on
CS0
[ 0.000000] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver,
5 countee
[ 0.000000] Switched to new clocking rate (Crystal/Core/MPU):
26.0/800/332 Mz
[ 0.000122] OMAP DMA hardware revision
5.0
[ 0.000396] omap-mcpdm omap-mcpdm: unable to get pdm_ck:
-2
[ 0.000457] omap-mcpdm: probe of omap-mcpdm failed with error
-2
[ 0.004028] bio: create slab <bio-0> at
0
[ 0.004852] SCSI subsystem
initialized
[ 0.005584] usbcore: registered new interface driver
usbfs
[ 0.005676] usbcore: registered new interface driver
hub
[ 0.005859] usbcore: registered new device driver
usb
[ 0.006134] i2c_omap i2c_omap.1: bus 1 rev4.0 at 2600
kHz
[ 0.008392] twl4030: PIH (irq 7) chaining IRQs
368..375
[ 0.008453] twl4030: power (irq 373) chaining IRQs
376..383
[ 0.008850] twl4030: gpio (irq 368) chaining IRQs
384..401
[ 0.011322] regulator: VUSB1V5: 1500 mV normal
standby
[ 0.011596] regulator: VUSB1V8: 1800 mV normal
standby
[ 0.011840] regulator: VUSB3V1: 3100 mV normal
standby
[ 0.015258] twl4030_usb twl4030_usb: Initialized TWL4030 USB
module
[ 0.015686] regulator: VMMC1: 1850 <--> 3150 mV at 3000 mV normal
standby
[ 0.015991] regulator: VDAC: 1800 mV normal
standby
[ 0.016265] regulator: VPLL2: 1800 mV normal
standby
[ 0.016601] regulator: VSIM: 1800 <--> 3000 mV at 1800 mV normal
standby
[ 0.016815] i2c_omap i2c_omap.2: bus 2 rev4.0 at 400
kHz
[ 0.025970] i2c_omap i2c_omap.3: bus 3 rev4.0 at 100
kHz
[ 0.026641] Advanced Linux Sound Architecture Driver Version
1.0.23.
[ 0.027069] NetLabel:
Initializing
[ 0.027099] NetLabel: domain hash size =
128
[ 0.027130] NetLabel: protocols = UNLABELED
CIPSOv4
[ 0.027191] NetLabel: unlabeled traffic allowed by
default
[ 0.027252] Switching to clocksource
32k_counter
[ 0.043090] musb_hdrc: version 6.0, musb-dma, otg (peripheral
+host), debug=0
[ 0.043518] musb_hdrc musb_hdrc: USB OTG mode controller at
fa0ab000 using D2
[ 0.043792] NET: Registered protocol family
2
[ 0.044036] IP route cache hash table entries: 4096 (order: 2,
16384 bytes)
[ 0.044799] TCP established hash table entries: 16384 (order: 5,
131072 byte)
[ 0.045104] TCP bind hash table entries: 16384 (order: 4, 65536
bytes)
[ 0.045318] TCP: Hash tables configured (established 16384 bind
16384)
[ 0.045349] TCP reno
registered
[ 0.045349] UDP hash table entries: 256 (order: 0, 4096
bytes)
[ 0.045410] UDP-Lite hash table entries: 256 (order: 0, 4096
bytes)
[ 0.045623] NET: Registered protocol family
1
[ 0.046020] RPC: Registered udp transport
module.
[ 0.046051] RPC: Registered tcp transport
module.
[ 0.046081] RPC: Registered tcp NFSv4.1 backchannel transport
module.
[ 0.046356] Trying to unpack rootfs image as
initramfs...
[ 0.363189] Freeing initrd memory:
3848K
[ 0.363952] PMU: registered new PMU device of type
0
[ 0.364044] dspbridge_init: 600000 bytes @
82600000
[ 0.364501] audit: initializing netlink socket
(disabled)
[ 0.364593] type=2000 audit(0.718:1):
initialized
[ 0.478088] VFS: Disk quotas
dquot_6.5.2
[ 0.478393] Dquot-cache hash table entries: 1024 (order 0, 4096
bytes)
[ 0.482238] fuse init (API version
7.14)
[ 0.483520] Btrfs
loaded
[ 0.483581] msgmni has been set to
955
[ 0.485443] alg: No test for stdrng
(krng)
[ 0.485839] Block layer SCSI generic (bsg) driver version 0.4
loaded (major )
[ 0.485870] io scheduler noop
registered
[ 0.485900] io scheduler deadline
registered
[ 0.485992] io scheduler cfq registered
(default)
[ 0.543121] OMAP DSS rev
2.0
[ 0.543212] OMAP DISPC rev
3.0
[ 0.543273] OMAP VENC rev
2
[ 0.871856] Serial: 8250/16550 driver, 4 ports, IRQ sharing
enabled
[ 0.952667] serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a
ST16654
[ 1.116241] serial8250.1: ttyS1 at MMIO 0x4806c000 (irq = 73) is a
ST16654
[ 1.279724] serial8250.2: ttyS2 at MMIO 0x49020000 (irq = 74) is a
ST16654
[ 2.175140] console [ttyS2]
enabled
[ 2.184143] brd: module
loaded
[ 2.189819] loop: module
loaded
[ 2.195281] omap2-nand driver
initializing
[ 2.199707] No NAND device
found.
[ 2.203186] No NAND device
found.
[ 2.206695] OneNAND driver
initializing
[ 2.210906] usbcore: registered new interface driver
cdc_ether
[ 2.216888] usbcore: registered new interface driver
rndis_host
[ 2.223388] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI)
Driver
[ 2.230194] ehci-omap ehci-omap.0: OMAP-EHCI Host
Controller
[ 2.236206] ehci-omap ehci-omap.0: new USB bus registered, assigned
bus numb1
[ 2.243835] ehci-omap ehci-omap.0: irq 77, io mem
0x48064800
[ 2.261749] ehci-omap ehci-omap.0: USB 2.0 started, EHCI
1.00
[ 2.268188] hub 1-0:1.0: USB hub
found
[ 2.272033] hub 1-0:1.0: 3 ports
detected
[ 2.300903] Initializing USB Mass Storage
driver...
[ 2.305938] usbcore: registered new interface driver usb-
storage
[ 2.312042] USB Mass Storage support
registered.
[ 2.316772] g_ether gadget: using random self ethernet
address
[ 2.322662] g_ether gadget: using random host ethernet
address
[ 2.329376] usb0: MAC b2:d2:c2:a5:5a:
6e
[ 2.333282] usb0: HOST MAC c2:c1:a5:fa:
97:7d
[ 2.337646] g_ether gadget: Ethernet Gadget, version: Memorial Day
2008
[ 2.344329] g_ether gadget: g_ether
ready
[ 2.348419] musb_hdrc musb_hdrc: MUSB HDRC host
driver
[ 2.353851] musb_hdrc musb_hdrc: new USB bus registered, assigned
bus number2
[ 2.361724] hub 2-0:1.0: USB hub
found
[ 2.365570] hub 2-0:1.0: 1 port
detected
[ 2.370025] mice: PS/2 mouse device common for all
mice
[ 2.376068] input: twl4030_pwrbutton as /devices/platform/i2c_omap.
1/i2c-1/10
[ 2.386901] i2c /dev entries
driver
[ 2.391479] device-mapper: uevent: version
1.0.3
[ 2.397003] device-mapper: ioctl: 4.17.0-ioctl (2010-03-05)
initialised: dm-m
[ 2.405853] device-mapper: multipath: version 1.1.1
loaded
[ 2.411437] device-mapper: multipath round-robin: version 1.0.0
loaded
[ 2.418670] sdhci: Secure Digital Host Controller Interface
driver
[ 2.424926] sdhci: Copyright(c) Pierre
Ossman
[ 2.432373] mmci-omap-hs: probe of mmci-omap-hs.1 failed with error
-16
[ 2.442565] No device for DAI
tlv320aic23
[ 2.527740] No device for DAI omap-mcbsp-
dai-0
[ 2.532226] No device for DAI omap-mcbsp-
dai-1
[ 2.536743] No device for DAI omap-mcbsp-
dai-2
[ 2.541229] No device for DAI omap-mcbsp-
dai-3
[ 2.545745] No device for DAI omap-mcbsp-
dai-4
[ 2.550231] No device for DAI omap-
mcpdm
[ 2.554229] Not OMAP3
EVM!
[ 2.556945] Not OMAP3517 / AM3517
EVM!
[ 2.560760] OMAP3 Beagle/Devkit8000 SoC
init
[ 2.565734] asoc: twl4030 <-> omap-mcbsp-dai-0 mapping
ok
[ 2.573913] ALSA device
list:
[ 2.576995] #0: omap3beagle
(twl4030)
[ 2.582153] TCP cubic
registered
[ 2.586212] NET: Registered protocol family
10
[ 2.592071] lo: Disabled Privacy
Extensions
[ 2.597900] NET: Registered protocol family
17
[ 2.602600] ThumbEE CPU extension
supported.
[ 2.608398] Power Management for TI
OMAP3.
[ 2.619415] VFP support v0.3: implementor 41 architecture 3 part 30
variant 3
[ 2.627929] registered taskstats version
1
[ 2.632293] fbcvt: 1280x720@60: CVT Name - .921M9-
R
[ 2.657073] Console: switching to colour frame buffer device
160x45
[ 2.673858] regulator_init_complete: incomplete constraints,
leaving VDAC on
[ 2.681457] Freeing init memory:
264K
[ 2.699523] usb 1-2: new high speed USB device using ehci-omap and
address 2
[ 2.801086] mmc0: host does not support reading read-only switch.
assuming w.
[ 2.813446] udev[62]: starting version
163
[ 2.822082] mmc0: new high speed SDHC card at address
1234
[ 2.871520] mmcblk0: mmc0:1234 SA04G 3.67
GiB
[ 2.876464]
mmcblk0:
[ 2.881835] hub 1-2:1.0: USB hub
found
[ 2.957366] p1
p2
[ 2.970794] hub 1-2:1.0: 5 ports
detected
[ 3.434020] usb 1-2.1: new high speed USB device using ehci-omap
and address3
data mode. )
Is this 10.04 or 10.10 and what's on your DVI/LCD screen?
I have the same problème on Ubuntu 10.04.
CPU: Core i7
MB : ASUS P7P55D-E
HD : Maxtor STM3500320AS (500 Go)
Thanks for the help.
Eric
CPU: Core i7
MB : ASUS P7P55D-E
There is just a white caret on the screen.
Eric
If that's the case, then there isn't much else we can do..
Rerun setup_sdcard.sh with the option "--use-default-user" then you'll
have access via the serial port so we can figure out why your dvi
monitor isn't coming up..
