I’d like to be able to stop and later restart cloud9. The following stopped cloud9
bone$ sudo systemctl stop cloud9
But the following didn’t restart it.
bone$ sudo systemctl start cloud9
bone$ systemctl status cloud9
● cloud9.service - Cloud9 IDE
Loaded: loaded (/lib/systemd/system/cloud9.service; static; vendor preset: enabled)
Active: failed (Result: exit-code) since Sat 2020-01-04 19:45:12 UTC; 2s ago
Process: 5485 ExecStartPre=/opt/cloud9/cloud9-symlink (code=exited, status=0/SUCCESS)
Process: 5491 ExecStart=/opt/cloud9_support/bin/node server.js --packed -w /var/lib/cloud9 (code=exited, status=1/FAILURE)
Main PID: 5491 (code=exited, status=1/FAILURE)
Jan 04 19:45:12 ece312 cloud9ide[5491]: port: ‘3000’,
Jan 04 19:45:12 ece312 cloud9ide[5491]: host: ‘127.0.0.1’,
Jan 04 19:45:12 ece312 cloud9ide[5491]: websocket: true,
Jan 04 19:45:12 ece312 cloud9ide[5491]: showRealIP: true,
Jan 04 19:45:12 ece312 cloud9ide[5491]: secure: undefined,
Jan 04 19:45:12 ece312 cloud9ide[5491]: provides: [ ‘connect’, ‘http’ ],
Jan 04 19:45:12 ece312 cloud9ide[5491]: consumes: [],
Jan 04 19:45:12 ece312 cloud9ide[5491]: setup: [Function: startup] } } 'Error: No or too many file descriptors received.\n at Server.listen (/opt/cloud9/node_modules
Jan 04 19:45:12 ece312 systemd[1]: cloud9.service: Main process exited, code=exited, status=1/FAILURE
Jan 04 19:45:12 ece312 systemd[1]: cloud9.service: Failed with result ‘exit-code’.
bone$ cat /ID.txt
BeagleBoard.org Debian Image 2019-12-16
bone $ uname -a
Linux ece312 4.19.79-ti-r30 #1buster SMP PREEMPT Mon Nov 4 20:38:01 UTC 2019 armv7l GNU/Linux
Or is there a better way to turn off cloud9 access and restore it later?
–Mark
