Hello all, I thought I’d share my u-boot struggles I had tonight with you. Maybe you can shed some light on what went wrong, and what went right.
So before we start, you need to know that I love Arch linux, btrfs, and snapper. the snapper utility itself would be great for the experimentation I do on the BBB because it allows easy snapshots and rollbacks of the file system.
So anyway. I decided I wanted to get my device going with arch and btrfs. So I dig around and realize that uboot doesn’t support btrfs yet; however there seems to be a rogue uboot git repo which claims to have btrfs up and going (https://github.com/falstaff84/u-boot). So I download this repo, compile and put it on my SD card.
Yet, every time I bootup my device, even when holding the boot button, I notice that the timestamp for uboot is not the same as what I compiled. So I get smart, and cp the MLO and u-boot.img from my SD card to the eMMC. After this, I notice the timestamp for the uboot is todays date. Great… Except this uboot doesn’t boot my kernels.
I reformat my SD card to the BBBArch default, but still, the eMMC uboot is being used, and I cant load my kernels. Even when holding down the boot buttons.
So in a desparate attempt to save myself, I grab RCNs eMMC flasher image (
[https://rcn-ee.net/deb/flasher/wheezy/BBB-eMMC-flasher-debian-7.4-2014-02-16-2gb.img.xz](https://rcn-ee.net/deb/flasher/wheezy/BBB-eMMC-flasher-debian-7.4-2014-02-16-2gb.img.xz)). Throw it on the SD card and pray.
Prayers are answered, as the device immediately boots from the SD card's uboot rather than the MMC.
Anyways. Here is the error I was getting. Any ideas why RCNs image used the SD for uboot, but the BBBArch image didn't?
U-Boot SPL 2013.07-rc1-g13e4350 (Feb 24 2014 - 20:35:37)
musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 2.0
musb-hdrc: setup fifo_mode 4
musb-hdrc: 28/31 max ep, 16384/16384 memory
USB Peripheral mode controller at 47401000 using PIO, IRQ 0
USB Host mode controller at 47401800 using PIO, IRQ 0
OMAP SD/MMC: 0
mmc_send_cmd : timeout: No status update
reading args
spl: error reading image args, err - -1
reading u-boot.img
reading u-boot.img
U-Boot 2013.07-rc1-g13e4350 (Feb 24 2014 - 20:35:37)
I2C: ready
DRAM: 512 MiB
WARNING: Caches not enabled
NAND: 0 MiB
cpsw, usb_ether
syntax error
mmc0 is current device
SD/MMC found on device 0
reading uEnv.txt
681 bytes read in 4 ms (166 KiB/s)
Running uenvcmd …
3309688 bytes read in 562 ms (5.6 MiB/s)
24884 bytes read in 43 ms (564.5 KiB/s)
Booting from mmc …
ERROR: booting os ‘Invalid OS’ (0) is not supported
