strange error when running simple *.js file setting a pin to output using beaglebone black Rev C.
Hello! How’s everything?
I encountered strange error when running simple *.js file
setting a pin to output using beaglebone black Rev C which I received this August.
I even reinstalled bonescript using
“npm install -g bonescript”
but still encounter the same error message.
led = “P9_11”, “9_12” worked
led = “P8_39”, “P8_40”, “P8_41”, and many other pins
do not work with error message listed below
following “simpleDigitalOut.js”:
//simpleDigitalOut.js
var b = require(’/usr/local/lib/node_modules/bonescript’);
var led = “P8_41”;
b.pinMode(led, b.OUTPUT);
console.log(“end of program”);
root@beaglebone:/var/lib/cloud9/myProg# node simpleDigitalOut.js
/usr/local/lib/node_modules/bonescript/my.js:57
if(slot[0]) {
TypeError: Cannot read property ‘0’ of null
at Object.exports.load_dt (/usr/local/lib/node_modules/bonescript/my.js:57:20)
at Object.exports.create_dt (/usr/local/lib/node_modules/bonescript/my.js:123:33)
at Object.exports.setPinMode (/usr/local/lib/node_modules/bonescript/hw_capemgr.js:83:12)
at Object.f.pinMode (/usr/local/lib/node_modules/bonescript/index.js:160:15)
at Object. (/var/lib/cloud9/myProg/simpleDigitalOut.js:4:3)
at Module._compile (module.js:456:26)
at Object.Module._extensions…js (module.js:474:10)
at Module.load (module.js:356:32)
at Function.Module._load (module.js:312:12)
at Function.Module.runMain (module.js:497:10)
I googled but cannot find a solution to this problem.
It would be a great help if you can guide me through it.
your advice is very much appreciated.
Many thanks,
Fung Yang
Did you try the number zero rather than the letter Oh?
Chad
Hi.
I use beaglebone-green and i try enable P8_15.
In folder /lib/firmware i found files bspm_P8_15_27-00A0.dts and bspm_P8_15_27-00A0.dtbo
I try enable PIN with command
echo bspm_P8_15_27 > /sys/devices/bone_capemgr.9/slots
but result was with error
Then I edit file bspm_P8_15_27-00A0.dts
change line
compatible = “ti,beaglebone”, “ti,beaglebone-black”;
to
compatible = “ti,beaglebone”, “ti,beaglebone-black”, “ti,beaglebone-green”;
Rebuilt file with command
dtc -@ -I dts -O dtb -o bspm_P8_15_27-00A0.dtbo bspm_P8_15_27-00A0.dts
Then I try command
and result is OK.
Content /sys/devices/bone_capemgr.9/slots is
0: 54:P—L 4D 7.0 LCD CAPE- 4DCAPE-70T ,00A3,4D SYSTEMS ,BB-BONE-LCD7-01
1: 55:PF—
2: 56:PF—
3: 57:PF—
4: ff:P-O-L Bone-LT-eMMC-2G,00A0,Texas Instrument,BB-BONE-EMMC-2G
6: ff:P-O-L Override Board Name,00A0,Override Manuf,bspm_P8_15_27
Now i can use PIN P8_15.
Sorry for my english.
I wish help you.
Dne středa 20. srpna 2014 11:06:04 UTC+2 fung…@auckland.ac.nz napsal(a):
