Hello! How’s everything?
I encountered strange error when running simple *.js file
setting a pin (GPIO) to output using beaglebone black Rev C, which I received this August.
I even reinstalled bonescript using
“npm install -g bonescript”
but still encounter the same error message.
led = “P9_11”, “9_12” worked
led = “P8_39”, “P8_40”, “P8_41”, and many other pins
does not work with error message listed below
following “simpleDigitalOut.js”:
//simpleDigitalOut.js
var b = require(’/usr/local/lib/node_modules/bonescript’);
var led = “P8_41”;
b.pinMode(led, b.OUTPUT);
console.log(“end of program”);
root@beaglebone:/var/lib/cloud9/myProg# node simpleDigitalOut.js
/usr/local/lib/node_modules/bonescript/my.js:57
if(slot[0]) {
TypeError: Cannot read property ‘0’ of null
at Object.exports.load_dt (/usr/local/lib/node_modules/bonescript/my.js:57:20)
at Object.exports.create_dt (/usr/local/lib/node_modules/bonescript/my.js:123:33)
at Object.exports.setPinMode (/usr/local/lib/node_modules/bonescript/hw_capemgr.js:83:12)
at Object.f.pinMode (/usr/local/lib/node_modules/bonescript/index.js:160:15)
at Object. (/var/lib/cloud9/myProg/simpleDigitalOut.js:4:3)
at Module._compile (module.js:456:26)
at Object.Module._extensions…js (module.js:474:10)
at Module.load (module.js:356:32)
at Function.Module._load (module.js:312:12)
at Function.Module.runMain (module.js:497:10)
I googled but cannot find a solution to this problem.
It would be a great help if you can guide me through it.
your advice is very much appreciated.
Many thanks,
Fung Yang
