I am new to the Beaglebone, and was moving along at a pretty good click until this strange problem popped-up. I spent all weekend trying to figure it out before posting here.
I am trying to read analog input using multiple sensors from a beaglebone with Angstrom 3.2.5+ and I have a problem that I think might be a hardware issue.
Using this Python script and Alexander Hiam's PyBBIO I have been able to test a photoresistor with success (the value responds to more and less incidental light):
https://gist.github.com/2698550
But...
1. Any other analog-in (AINx(2-7)) I read with the script above always shows the same value of the photo resistor I have plugged-into AIN1
And, possibly related...
2. I am unable to read any of the AINx(1-7) using cat with an error:
# cat /sys/bus/platform/devices/tsc/ain1
Segmentation fault
Any ideas? I am really stuck. Thanks in advance.
Owen
PS:
More info...
My circuit consists of a 10k resistor and a photoresistor. My pin connections are:
• Header P9 Pin 32 (VDD_ADC(1.8V)) to one end of photocell
• Header P9 Pin 34 (GNDA_ADC) to the other end of the resistor
• Header P9 Pin 39 (AIN0) to the other side of the photocell along with one end of pull down resistor
Here is an image which matches my own circuit:
http://2.bp.blogspot.com/-6XuT3btrNsk/T5DGlIt0oeI/AAAAAAAAAAQ/xXac6xQkLUg/s1600/Smalltalk+on+the+BeagleBone.png
The results from all of the AINx(1-7)'s and then some...
# cat /sys/bus/platform/devices/tsc/ain0
cat: /sys/bus/platform/devices/tsc/ain0: No such file or directory
Segmentation fault
# cat /sys/bus/platform/devices/tsc/ain2
Segmentation fault
# cat /sys/bus/platform/devices/tsc/ain3
Segmentation fault
# cat /sys/bus/platform/devices/tsc/ain4
Segmentation fault
# cat /sys/bus/platform/devices/tsc/ain5
Segmentation fault
# cat /sys/bus/platform/devices/tsc/ain6
Segmentation fault
# cat /sys/bus/platform/devices/tsc/ain7
Segmentation fault
# cat /sys/bus/platform/devices/tsc/ain8
Segmentation fault
# cat /sys/bus/platform/devices/tsc/ain9
cat: /sys/bus/platform/devices/tsc/ain9: No such file or directory
