Just downloaded latest stretch LXQT image (June 11,2017). Flashed sd card and popped it in. First boot worked fine, executed grow_partition script and rebooted. GUI boot failed (all i see is a blinking cursor which never seems to go away), but I was able to ssh. Rebooted a few more times, same issue. Flashed sd-card again, first boot worked fine. Rebooted the system (without executing any scripts), gui boot failed again, stuck with a bling cursor again, but I am able to ssh. Have attached a copy of syslog and kern.log.
I am not sure but I suspect the problem is with limghtdm.service failing.
From syslog:
Jun 13 15:44:12 beaglebone systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
Jun 13 15:44:12 beaglebone systemd[1]: lightdm.service: Unit entered failed state.
Jun 13 15:44:12 beaglebone systemd[1]: lightdm.service: Failed with result ‘exit-code’.
debian@beaglebone:~$ systemctl status lightdm
● lightdm.service - Light Display Manager
Loaded: loaded (/lib/systemd/system/lightdm.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Tue 2017-06-13 15:44:37 UTC; 14min ago
Docs: man:lightdm(1)
Process: 1464 ExecStart=/usr/sbin/lightdm (code=exited, status=1/FAILURE)
Process: 1458 ExecStartPre=/bin/sh -c [ “$(cat /etc/X11/default-display-manager 2>/dev/null)” = “/usr/sbin/lightdm” ] (code=exited, status=0/SUCCESS)
Main PID: 1464 (code=exited, status=1/FAILURE)
Jun 13 15:44:36 beaglebone systemd[1]: lightdm.service: Failed with result ‘exit-code’.
Jun 13 15:44:37 beaglebone systemd[1]: lightdm.service: Service hold-off time over, scheduling restart.
Jun 13 15:44:37 beaglebone systemd[1]: Stopped Light Display Manager.
Jun 13 15:44:37 beaglebone systemd[1]: lightdm.service: Start request repeated too quickly.
Jun 13 15:44:37 beaglebone systemd[1]: Failed to start Light Display Manager.
Jun 13 15:44:37 beaglebone systemd[1]: lightdm.service: Unit entered failed state.
Jun 13 15:44:37 beaglebone systemd[1]: lightdm.service: Failed with result ‘exit-code’.
debian@beaglebone:~$ uname -a
Linux beaglebone 4.4.68-ti-r108 #1 SMP Fri Jun 9 20:14:30 UTC 2017 armv7l GNU/Linux
lightdm log:
root@beaglebone:/var/log/lightdm# less lightdm.log
[+0.01s] DEBUG: Loading configuration from /usr/share/lightdm/lightdm.conf.d/01_debian.conf
[+0.01s] DEBUG: Loading configuration dirs from /usr/local/share/lightdm/lightdm.conf.d
[+0.01s] DEBUG: Loading configuration dirs from /etc/xdg/lightdm/lightdm.conf.d
[+0.01s] DEBUG: Loading configuration from /etc/lightdm/lightdm.conf
[+0.01s] DEBUG: Using D-Bus name org.freedesktop.DisplayManager
[+0.02s] DEBUG: Registered seat module xlocal
[+0.02s] DEBUG: Registered seat module xremote
[+0.02s] DEBUG: Registered seat module unity
[+0.37s] DEBUG: Monitoring logind for seats
[+0.37s] DEBUG: New seat added from logind: seat0
[+0.37s] DEBUG: Seat seat0: Loading properties from config section Seat:*
[+0.37s] DEBUG: Seat seat0: Starting
[+0.37s] DEBUG: Seat seat0: Creating user session
[+0.39s] WARNING: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
[+0.42s] DEBUG: Loading user config from /etc/lightdm/users.conf
[+0.42s] DEBUG: User debian added
[+0.44s] DEBUG: Seat seat0: Creating display server of type x
[+0.46s] DEBUG: Could not run plymouth --ping: Failed to execute child process “plymouth” (No such file or directory)
[+0.46s] DEBUG: Using VT 7
[+0.46s] DEBUG: Seat seat0: Starting local X display on VT 7
[+0.47s] DEBUG: DisplayServer x-0: Logging to /var/log/lightdm/x-0.log
[+0.47s] DEBUG: DisplayServer x-0: Writing X server authority to /var/run/lightdm/root/:0
[+0.47s] DEBUG: DisplayServer x-0: Launching X Server
[+0.48s] DEBUG: Launching process 1471: /usr/bin/X :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
[+0.48s] DEBUG: DisplayServer x-0: Waiting for ready signal from X server :0
[+0.48s] DEBUG: Acquired bus name org.freedesktop.DisplayManager
[+0.50s] DEBUG: Registering seat with bus path /org/freedesktop/DisplayManager/Seat0
[+0.81s] DEBUG: Process 1471 exited with return value 1
[+0.81s] DEBUG: DisplayServer x-0: X server stopped
[+0.81s] DEBUG: Releasing VT 7
[+0.81s] DEBUG: DisplayServer x-0: Removing X server authority /var/run/lightdm/root/:0
[+0.81s] DEBUG: Seat seat0: Display server stopped
[+0.81s] DEBUG: Seat seat0: Stopping session
[+0.81s] DEBUG: Seat seat0: Session stopped
[+0.81s] DEBUG: Seat seat0: Stopping display server, no sessions require it
[+0.81s] DEBUG: Seat seat0: Active display server stopped, starting greeter
[+0.81s] DEBUG: Seat seat0: Creating greeter session
[+0.82s] DEBUG: Seat seat0: Creating display server of type x
[+0.82s] DEBUG: Using VT 7
[+0.82s] DEBUG: Seat seat0: Starting local X display on VT 7
[+0.82s] DEBUG: DisplayServer x-0: Logging to /var/log/lightdm/x-0.log
[+0.82s] DEBUG: DisplayServer x-0: Writing X server authority to /var/run/lightdm/root/:0
[+0.83s] DEBUG: DisplayServer x-0: Launching X Server
[+0.83s] DEBUG: Launching process 1478: /usr/bin/X :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
[+0.83s] DEBUG: DisplayServer x-0: Waiting for ready signal from X server :0
[+1.12s] DEBUG: Process 1478 exited with return value 1
[+1.12s] DEBUG: DisplayServer x-0: X server stopped
[+1.12s] DEBUG: Releasing VT 7
[+1.12s] DEBUG: DisplayServer x-0: Removing X server authority /var/run/lightdm/root/:0
[+1.12s] DEBUG: Seat seat0: Display server stopped
[+1.12s] DEBUG: Seat seat0: Stopping; greeter display server failed to start
[+1.12s] DEBUG: Seat seat0: Stopping session
[+1.12s] DEBUG: Seat seat0: Session stopped
[+1.12s] DEBUG: Seat seat0: Stopped
[+1.12s] DEBUG: Required seat has stopped
[+1.12s] DEBUG: Stopping display manager
[+1.12s] DEBUG: Display manager stopped
[+1.12s] DEBUG: Stopping daemon
[+1.13s] DEBUG: Seat seat0: Stopping session
[+1.15s] DEBUG: Exiting with return value 1
x-0.log
X.Org X Server 1.19.2
Release Date: 2017-03-02
X Protocol Version 11, Revision 0
Build Operating System: Linux 3.16.0-4-armmp-lpae armv7l Debian
Current Operating System: Linux beaglebone 4.4.68-ti-r108 #1 SMP Fri Jun 9 20:14:30 UTC 2017 armv7l
Kernel command line: console=ttyO0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 quiet
Build Date: 03 March 2017 03:23:00PM
xorg-server 2:1.19.2-1 (https://www.debian.org/support)
Current version of pixman: 0.34.0
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (–) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: “/var/log/Xorg.0.log”, Time: Tue Jun 13 15:44:36 2017
(==) Using config file: “/etc/X11/xorg.conf”
(==) Using system config directory “/usr/share/X11/xorg.conf.d”
(EE)
Fatal server error:
(EE) no screens found(EE)
(EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
(EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
(EE)
(EE) Server terminated with error (1). Closing log file.
Wondering if anyone else is facing the same problem and how do I resolve this issue?
Gaurav
syslog (176 KB)
kern.log (82.8 KB)
