Hi There,
I have recently took my Beagleboard-xM and put on it the Ubuntu 14.04 LTS (3.14.2-armv7-x5),
then I tried to mux PIn3 (GPIO_139), after reading thoroughly the pages from both the “System Reference Manual”(Page 110) and the “Technical Reference Manual” of the processor (Pages 2444-2453).
So I wrote the dts file and compiled it via dtc.
but now I got stuck how do I apply the changes on runtime?
I saw on the beaglebone there is a slots file (/sys/devices/…/slots) which was triggering the change,
after we echoed to it the dtbo file. but in my case we are talking about beagleboard-xM which there is no such kind of file.
can someone elaborate what should I do?
A short question before I’ll read and delve into more depth about the subject:
I have noticed during the boot process, the beagleboard-xM (rev B) prints on screen:
"reading /dtbs/omap3-beagle-xm-ab.dtb
60695 bytes read in 13 ms (4.5 MiB/s)
Error: “expansion_args” not defined
Kernel image @ 0x80300000 [ 0x000000 - 0x3e2f38 ]
Flattened Device Tree blob at 815f0000
Booting using the fdt blob at 0x815f0000
Using Device Tree in place at 815f0000, end 81601d16
Starting kernel …"
So I searched for the omap3-beagle-xm-ab.dts (on linux_kernel-3.14.4 source) in order to modify it. but couldn’t find it, found only omap3-beagle-xm.dts
googled and found only this skinny file: omap3-beagle-xm-ab.dts, which contains:
/include/ “omap3-beagle-xm.dts”
/* On Rev A/B USBHOST_PWR_EN is active high */
&hsusb2_power {
enable-active-high;
Is it the correct file? which I should:
modify
compile it to dtb
overwrite the exist file in /boot/uboot/dtbs/omap3-beagle-xm-ab.dtb
A short question before I'll read and delve into more depth about the
subject:
on screen:
## Error: "expansion_args" not defined
That's just an old variable in u-boot for the old "board" file boot. (the
buddy=spidev etc crap)
## Flattened Device Tree blob at 815f0000
Starting kernel .."
source) in order to modify it. but couldn't find it, found only
omap3-beagle-xm.dts
contains:
Yeah, just got merged to mainline a few weeks back.
Gilco, could you post the code you ended up using to get this to work? I am in the same boat, I just want to use some GPIO pins for basic I/O but this new device tree thing is making it hard. Cannot find any information on how to simply export a few pins.
I would really appreciate any help!
~Dagaen Golomb
