Suitable power supply available in UK
Hi there
Does anyone know where to get a suitable DC power supply for the Beagleboard in the UK?
This is the best one I found:
http://www.poweradaptorsuk.co.uk/index.php?cat=5_volt_adaptors&ActinicSID=e547b65995feacd5eb21e31d8ea74bc4
But I'm sure I read somewhere that the maximum current should be 2A and this one is 2.5A. All the other ones I have found do 4.5V & 6V but no 5V.
Thanks in advance,
Mark
The maximum current drawn by the beagleboard is 2A, so any regulated
supply that provides >=2A will be fine. Be careful that you get the
polarity right and that the jack is a good tight fit.
I got my power supply from the local Maplin electronics but they tend
to be a bit pricier.
Good luck
Jon
Mark Craig wrote:
I don't know if they're the cheapest, but I use and can recommend
Rapid who stock Power Pax adapters:
http://www.rapidonline.com/Electrical-Power/Power-Supplies/Plug-In-PSUs/15W-Mini-plugtop-switch-mode-PSU/71059
I find it much more convenient to supply power via a USB A to mini B
cable, which you can pick up on ebay for next to nothing.
