Hi all,
I'm playing around with my new BeagleBaby XM Rev C, and I had a lot of trouble
getting working the USB Hub + Ethernet, trying different distros, ( ubuntu natty &
oneiric, Robert Nelsons verisons, an Angstrom ones).
All distros are running, except USB & ethernet ( g_ether is workig as well ), so
yesterday a took the scope to make some measurements:
- nUSBHOST_PWR_EN is low, so it shoud be ok
- DC_5V_USB on Pin 1&2 of U16 is well 5V
- HUB_3V3 is just 1,2V, so i think
* U16 ( TL1963A ) has gone, but lifting the output pin 4 I can measure 5V
* someone is drawing a lot of current, but DC_5V_USB is well 5V, and i didn't
notice much heat at the IC
* the board draws max .5A @ 5V at the input, not more
The Ethernet port worked well initially with the pre installed image.
lsusb:
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
uname -a:
Linux beagleboard 3.0.4+ #1 Mon Sep 26 12:19:40 EDT 2011 armv7l GNU/Linux
currently running:
- esc-20110927-final.img with ulcd7
Any suggestions, has someone gone ?
Cheers,
~ andi
