Hello ,
I am using linux-omap-2.6.29 kernel for beagle board which uses tps65950.
Is that kernel supports tps65930?if not what changes need to be done for the kernel?
thank you
Hello ,
thank you
hi. which board do you use? do you mean the audio decoder chip is tps65950? I have a board which use that chip as audio chip.
I can’t get its audio to work properly.
