Hi All,
It seems that Symbian has open sourced its EKA2 kernel and they have
it up and running on BB! Has anyone tried it in this group!
I am planning to try it out this weekend.
Would post on the progress here.
Regards
kozak
Hi All,
Regards
kozak
Really a good info.
Cheers,
SK
Any news here?
I'm interested on Symbian running on BeagleBoard too.
There some useful information on Symbian developer area
http://developer.symbian.org/wiki/index.php/Kernel_%26_Hardware_Services_Quick_Start
But I didn't have a Windows machine to try out and wine didn't work to
install ARM RVCT 4.0. I expect try again on this weekend (now
following the steps on Windows) and put the results here.
--tm
Hi Same thing here... hopefully will try it out this weekend !!!
Br
Kozak
Kozak,
After installed RVCT 4.0 and Kernel Taster Kit on a Windows XP (SP2)
box I tried qemu (arm-none-symbianelf-qemu-system) and I got
"Application not initialized correctly (0xc0150002)". So I decided to
pass this step and go to Beagle Board setup, but some "sbs" utility
which I don't have.
Do you had any success? I following the procedure described in
--tm
Me too ... I have not yet tried it... dont have a windows machine :
Anyways, I did a quick search in the project dir,
http://developer.symbian.org/xref/oss/search?q=sbs&project=/MCL
and it seems sbs is a .bat file that gets created..... I would suggest
you to post the question in the symbian forums as well.
I think we might be missing a step or two here...
lets see..
BR
Kozak
Ok here is the thing,
SBS stands for Symbian Build System. It seems it comes along with the
PDT (not yet sure where to get that ....).
You can check it out in the "Running the Build" section here (http://
developer.symbian.org/wiki/index.php/How_to_Build_a_Package).
It looks more like a substitute/alternative to bldmake bldfiles + abld
build commands.
Tiago,
Please keep this thread updated on your developments ...
BR
Kozak
It was quite interesting and easy to work with kernel starter kit... i
had successfully build Qemu and beagleboard images and tested.....
here are the step which i had followed
- Install RVCT 4.0 from ARM
http://developer.symbian.org/wiki/index.php/Installing_ARM_RVCT_4.0
- Install PDT 1.3 above version which includes SBSv1 and SBSv2 tools
http://developer.symbian.org/wiki/index.php/Product_Development_Toolkit_Quick_Start
- Download the Kernel Starter kit or clone from Mercurial repository
http://developer.symbian.org/main/tools_and_kits/downloads/view.php?id=8
- To Build for Qemu or beagleboard image follow the steps as provided
in the below link
Regards
SD/-
