I already send a request on the BeagleBone google group : https://groups.google.com/forum/#!topic/beaglebone/OZdT-Mv40hc
Perhaps the BeagleBoard google group is more active.
There are about 300 people on that list and 6300 on this one. So based on those numbers, this one is a little more active.
I have two ideas.
It may be a version problem. I’m running v1.4.12 on my deskstop and it doesn’t seem to like v1.3.8 on the bone.
I used to have trouble ssh’ing into my Beagle and starting synergy. I have to attach a display and start it from there.
–Mark
Sure Gerald. I don’t understand why there is 2 google groups.
I’m sorry Mark, i didn’t understand your reply.
Did you make Synergy working ?
As I understand, you start synergy server with SSH without screen plugged and then plug the screen.
Does is it on BBB with Angstrom ?
This is the official group. Some people felt it would be less confusing to have a group that was just BeagleBone. So they started one.
I had synergy working the the past, but recently I’ve been unsuccessful in getting it to work with the BBB. I’m guessing if opkg installed the current version it might work.
–Mark
I don’t feel it’s a synergy problem but a X window problem.
It’s seems the error message “X Error of failed request” come from the X server. Like if the current window can’t be acceded.
I think i’m having the same issue here:
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 53 (X_CreatePixmap)
Value in failed request: 0x0
Serial number of failed request: 12
Current serial number in output stream: 13
2013-07-08T03:05:20 INFO: Synergy 1.3.8 Client on Linux 3.8.13 #1 SMP Tue Jun 18 02:11:09 EDT 2013 armv7l
/build/v2012.12/build/tmp-angstrom_v2012_12-eglibc/work/armv7a-vfp-neon-angstrom-linux-gnueabi/synergy-1.3.8-r0/synergy-1.3.8-Source/src/cmd/synergyc/synergyc.cpp,765
2013-07-08T03:05:20 DEBUG1: starting client
/build/v2012.12/build/tmp-angstrom_v2012_12-eglibc/work/armv7a-vfp-neon-angstrom-linux-gnueabi/synergy-1.3.8-r0/synergy-1.3.8-Source/src/cmd/synergyc/synergyc.cpp,406
2013-07-08T03:05:20 DEBUG: XOpenDisplay(":0")
/build/v2012.12/build/tmp-angstrom_v2012_12-eglibc/work/armv7a-vfp-neon-angstrom-linux-gnueabi/synergy-1.3.8-r0/synergy-1.3.8-Source/src/lib/platform/CXWindowsScreen.cpp,889
2013-07-08T03:05:20 DEBUG1: thread 0x00000002 entry
/build/v2012.12/build/tmp-angstrom_v2012_12-eglibc/work/armv7a-vfp-neon-angstrom-linux-gnueabi/synergy-1.3.8-r0/synergy-1.3.8-Source/src/lib/mt/CThread.cpp,154
---- Little bit of backstory ----
[Desktop Entry]
Name=SynergyClient
GenericName=Synergy Client
Exec=/usr/bin/start-synergy-client
Terminal=false
Type=Application
X-GNOME-Autostart-enabled=true
#!/bin/sh
synergyc --debug DEBUG2 --no-daemon X.X.X.X > /var/log/synergyc.log 2>&1 &
Any one have an idea what could be going on?
Thanks!
