Hello all,
I was trying the bone-debian-9.1-lxqt-armhf-2017-08-31-4gb.img.xz with a Newhaven NHD-7.0CTP-CAPE-N. It boots up fine and the screen and capacitive touchscreen work great. But I noticed this WARNING in the dmesg:
[ 31.517455] ------------[ cut here ]------------
[ 31.517513] WARNING: CPU: 0 PID: 347 at fs/sysfs/dir.c:31 sysfs_warn_dup+0x78/0x88
[ 31.517520] sysfs: cannot create duplicate filename ‘/bus/platform/devices/4a300000.pruss’
[ 31.517526] Modules linked in: pruss_soc_bus(+) joydev evdev uio_pdrv_genirq uio usb_f_mass_storage 8021q garp mrp stp llc usb_f_acm u_serial usb_f_ecm usb_f_rndis u_ether libcomposite iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack iptable_mangle iptable_filter spidev pru_rproc pruss_intc pruss tieqep ip_tables x_tables
[ 31.517659] CPU: 0 PID: 347 Comm: systemd-udevd Not tainted 4.9.76-ti-r91 #1
[ 31.517665] Hardware name: Generic AM33XX (Flattened Device Tree)
[ 31.517705] [] (unwind_backtrace) from [] (show_stack+0x20/0x24)
[ 31.517731] [] (show_stack) from [] (dump_stack+0x80/0x94)
[ 31.517747] [] (dump_stack) from [] (__warn+0xf8/0x110)
[ 31.517760] [] (__warn) from [] (warn_slowpath_fmt+0x58/0x74)
[ 31.517772] [] (warn_slowpath_fmt) from [] (sysfs_warn_dup+0x78/0x88)
[ 31.517788] [] (sysfs_warn_dup) from [] (sysfs_do_create_link_sd+0xc4/0xcc)
[ 31.517802] [] (sysfs_do_create_link_sd) from [] (sysfs_create_link+0x38/0x44)
[ 31.517820] [] (sysfs_create_link) from [] (bus_add_device+0x130/0x1b8)
[ 31.517834] [] (bus_add_device) from [] (device_add+0x298/0x5d0)
[ 31.517852] [] (device_add) from [] (of_device_add+0x44/0x4c)
[ 31.517867] [] (of_device_add) from [] (of_platform_device_create_pdata+0x94/0xcc)
[ 31.517879] [] (of_platform_device_create_pdata) from [] (of_platform_bus_create+0x174/0x30c)
[ 31.517891] [] (of_platform_bus_create) from [] (of_platform_populate+0x84/0x120)
[ 31.517924] [] (of_platform_populate) from [] (pruss_soc_bus_probe+0x12c/0x290 [pruss_soc_bus])
[ 31.517973] [] (pruss_soc_bus_probe [pruss_soc_bus]) from [] (platform_drv_probe+0x60/0xc0)
[ 31.517987] [] (platform_drv_probe) from [] (driver_probe_device+0x2b4/0x440)
[ 31.517999] [] (driver_probe_device) from [] (__driver_attach+0x100/0x10c)
[ 31.518009] [] (__driver_attach) from [] (bus_for_each_dev+0x8c/0xd0)
[ 31.518020] [] (bus_for_each_dev) from [] (driver_attach+0x2c/0x30)
[ 31.518031] [] (driver_attach) from [] (bus_add_driver+0x16c/0x26c)
[ 31.518043] [] (bus_add_driver) from [] (driver_register+0x88/0x104)
[ 31.518054] [] (driver_register) from [] (__platform_driver_register+0x50/0x58)
[ 31.518071] [] (__platform_driver_register) from [] (pruss_soc_bus_driver_init+0x20/0xc0 [pruss_soc_bus])
[ 31.518093] [] (pruss_soc_bus_driver_init [pruss_soc_bus]) from [] (do_one_initcall+0x64/0x1a0)
[ 31.518117] [] (do_one_initcall) from [] (do_init_module+0x74/0x3d0)
[ 31.518136] [] (do_init_module) from [] (load_module+0x1f40/0x2614)
[ 31.518149] [] (load_module) from [] (SyS_finit_module+0xdc/0x110)
[ 31.518167] [] (SyS_finit_module) from [] (__sys_trace_return+0x0/0x10)
[ 31.518175] —[ end trace 714a7bf4a57d0f0d ]—
This warning shows up with the 4.9.45-ti-r57 kernel from the image and with the 4.9.76-ti-r91 kernel after doing a sudo /opt/scripts/tools/update_kernel.sh.
Is this a known issue in the kernel or do I have something setup incorrectly?
This is the output from the versions.sh script:
$ sudo /opt/scripts/tools/version.sh
git:/opt/scripts/:[714e162ba98cf3d2897e7fc95e951c6df15a7d0a]
eeprom:[A335BNLT00C05014BBBK0A84]
dogtag:[BeagleBoard.org Debian Image 2017-08-31]
bootloader:[eMMC-(default)]:[/dev/mmcblk1]:[U-Boot 2018.01-00002-gcc9c2d1992]
kernel:[4.9.76-ti-r91]
nodejs:[v6.11.2]
uboot_overlay_options:[uboot_overlay_pru=/lib/firmware/AM335X-PRU-UIO-00A0.dtbo]
pkg:[bb-cape-overlays]:[4.4.20170728.0-0rcnee1~stretch+20170728]
pkg:[bb-wl18xx-firmware]:[1.20170829-0rcnee1~stretch+20170829]
pkg:[firmware-ti-connectivity]:[20170823-1rcnee0~stretch+20170830]
dmesg | grep pinctrl-single
[ 1.362988] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 1.750855] pinctrl-single 44e10800.pinmux: pin PIN95 already requested by ocp:P9_19_pinmux; cannot claim for 4819c000.i2c
[ 1.762096] pinctrl-single 44e10800.pinmux: pin-95 (4819c000.i2c) status -22
[ 1.769223] pinctrl-single 44e10800.pinmux: could not request pin 95 (PIN95) from group pinmux_bb_i2c2_pins on device pinctrl-single
END
I also notices this on the serial console when the board boots:
Starting kernel …
[ 0.000925] clocksource_probe: no matching clocksources found
[ 1.369280] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 1.648806] omap_voltage_late_init: Voltage driver support not added
[ 1.656162] PM: Cannot get wkup_m3_ipc handle
[ 1.781311] omap_i2c 4819c000.i2c: Error applying setting, reverse things back
[ 1.792167] PM: Cannot get wkup_m3_ipc handle
Do I need to change something?
Also, is there any documentation on what packages can be safely removed from this image for the BeagleBone Black? The image is pretty bloated:
$ df | grep /dev/mmc
/dev/mmcblk1p1 3704040 2927544 568624 84% /
Hartley
