systemd-logind.service fails in Debian
systemctl
systemd-logind.service loaded failed failed Login Service
Is this normal?
Well did you ask systemd about it?
debian@beaglebone:~$ systemctl status -l systemd-logind
● systemd-logind.service - Login Service
   Loaded: loaded (/lib/systemd/system/systemd-logind.service; static)
   Active: active (running) since Fri 2015-01-30 21:06:24 UTC; 1h 2min ago
     Docs: man:systemd-logind.service(8)
           man:logind.conf(5)
           http://www.freedesktop.org/wiki/Software/systemd/logind
           http://www.freedesktop.org/wiki/Software/systemd/multiseat
Main PID: 267 (systemd-logind)
   Status: "Processing requests..."
   CGroup: /system.slice/systemd-logind.service
           └─267 /lib/systemd/systemd-logind
Jan 30 21:06:24 beaglebone systemd-logind[267]: New seat seat0.
Jan 30 21:06:24 beaglebone systemd-logind[267]: Watching system
buttons on /dev/input/event0 (tps65217_pwr_but)
Jan 30 21:06:30 beaglebone systemd-logind[267]: New session c1 of user debian.
Jan 30 22:08:38 beaglebone systemd-logind[267]: New session c2 of user debian.
I think I have a problem here:
See, it looks like your missing: dbus:
sudo apt-get install dbus
This is a problem with the console version of the Debian image. I just tried a fresh install of 01/27/2015. Installing dbus does indeed fix the issue, thank you!
