I am not sure whether this is a Beaglebone or Angstrom issue, so I am posting it to both:
Over the past couple of weeks I have noticed that the build system appears to be unstable. Various errors relating to systemd and udev have appeared. Some workarounds have been suggested and seem to work for a while, but after ./oebb.sh update similar problems occur. Is this a known issue with Angstrom/Beaglebone? If so, is there a fix in the works? If not, could someone please guide me as to what I may be doing wrong.
Dave.
My work-flow is as follows:
cd ~/
rm -rf ~/beaglebone
mkdir -p ~/beaglebone
cd ~/beaglebone
git clone git://github.com/Angstrom-distribution/setup-scripts.git
cd setup-scripts
MACHINE=beaglebone ./oebb.sh config beaglebone
MACHINE=beaglebone ./oebb.sh update
. ~/.oe/environment-angstromv2012.05
bitbake systemd-image
<--snip-->
NOTE: Resolving any missing task queue dependencies
NOTE: preferred version 189 of systemd not available (for item udev)
NOTE: versions of systemd available: v189
NOTE: preferred version 189 of systemd not available (for item systemd)
NOTE: versions of systemd available: git v189
NOTE: preferred version 189 of systemd not available (for item udev-systemd)
NOTE: preferred version 189 of systemd not available (for item udev-utils)
NOTE: preferred version 189 of systemd not available (for item systemd-dev)
NOTE: Preparing runqueue
ERROR: Multiple .bb files are due to be built which each provide systemd (/home/dlambert/beaglebone/setup-scripts/sources/meta-openembedded/meta-oe/recipes-core/systemd/systemd_v189.bb /home/dlambert/beaglebone/setup-scripts/sources/meta-openembedded/meta-oe/recipes-core/systemd/systemd_git.bb).
This usually means one provides something the other doesn't and should.
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
NOTE: Running task 1553 of 3282 (ID: 1119, /home/dlambert/beaglebone/setup-scripts/sources/meta-ti/recipes-kernel/linux/linux-ti33x-psp_3.2.bb, do_package_write_ipk)
<--snip-->
checking pkg-config is at least version 0.9.0... yes
checking for UDEV... no
configure: error: Package requirements ( libudev >= 172 ) were not met:
No package 'libudev' found
Consider adjusting the PKG_CONFIG_PATH environment variable if you
installed software in a non-standard prefix.
Alternatively, you may set the environment variables UDEV_CFLAGS
and UDEV_LIBS to avoid the need to call pkg-config.
See the pkg-config man page for more details.
ERROR: oe_runconf failed
NOTE: package systemd-git-r28: task do_configure: Failed
ERROR: Task 165 (/home/dlambert/beaglebone/setup-scripts/sources/meta-openembedded/meta-oe/recipes-core/systemd/systemd_git.bb, do_configure) failed with exit code '1'
Waiting for 1 running tasks to finish:
0: linux-ti33x-psp-3.2.34-r18a+gitr720e07b4c1f687b61b147b31c698cb6816d72f01 do_package_write_ipk (pid 22350)
Can you post the banner at the start of the build so we know what layers/branches you are using?
I hope the following helps:
dlambert@development:~/beaglebone/setup-scripts$ bitbake systemd-image
NOTE: angstrom DOES NOT support libiconv because the eglibc provided iconv library is used | ETA: 00:00:11
Parsing recipes: 100%
NOTE: Running noexec task 1554 of 3282 (ID: 1114, /home/dlambert/beaglebone/setup-scripts/sources/meta-ti/recipes-kernel/linux/linux-ti33x-psp_3.2.bb, do_package_write)
NOTE: Running task 1827 of 3282 (ID: 165, /home/dlambert/beaglebone/setup-scripts/sources/meta-openembedded/meta-oe/recipes-core/systemd/systemd_git.bb, do_configure)
NOTE: Running task 1828 of 3282 (ID: 170, /home/dlambert/beaglebone/setup-scripts/sources/meta-openembedded/meta-oe/recipes-core/systemd/systemd_git.bb, do_populate_lic)
NOTE: package systemd-git-r28: task do_configure: Started
NOTE: package systemd-git-r28: task do_populate_lic: Started
NOTE: package systemd-git-r28: task do_populate_lic: Succeeded
