Hi Jason,
I wonder if the TESS WIRELESS SENSOR TAG DEMO V1.1 can be used to work with beaglebone black since I cannot retrieve the data of the available information from the beaglebone black as I think there are some characteristics missing :
you can find the data sheet from this link:
The following information is after I connect the sensor tag with the BBB:
handle: 0x0002, char properties: 0x02, char value handle: 0x0003, uuid: 00002a00-0000-1000-8000-00805f9b34fb
handle: 0x0004, char properties: 0x02, char value handle: 0x0005, uuid: 00002a01-0000-1000-8000-00805f9b34fb
handle: 0x0006, char properties: 0x0a, char value handle: 0x0007, uuid: 00002a02-0000-1000-8000-00805f9b34fb
handle: 0x0008, char properties: 0x08, char value handle: 0x0009, uuid: 00002a03-0000-1000-8000-00805f9b34fb
handle: 0x000a, char properties: 0x02, char value handle: 0x000b, uuid: 00002a04-0000-1000-8000-00805f9b34fb
handle: 0x000d, char properties: 0x20, char value handle: 0x000e, uuid: 00002a05-0000-1000-8000-00805f9b34fb
handle: 0x0011, char properties: 0x02, char value handle: 0x0012, uuid: 00002a23-0000-1000-8000-00805f9b34fb
handle: 0x0013, char properties: 0x02, char value handle: 0x0014, uuid: 00002a24-0000-1000-8000-00805f9b34fb
handle: 0x0015, char properties: 0x02, char value handle: 0x0016, uuid: 00002a25-0000-1000-8000-00805f9b34fb
handle: 0x0017, char properties: 0x02, char value handle: 0x0018, uuid: 00002a26-0000-1000-8000-00805f9b34fb
handle: 0x0019, char properties: 0x02, char value handle: 0x001a, uuid: 00002a27-0000-1000-8000-00805f9b34fb
handle: 0x001b, char properties: 0x02, char value handle: 0x001c, uuid: 00002a28-0000-1000-8000-00805f9b34fb
handle: 0x001d, char properties: 0x02, char value handle: 0x001e, uuid: 00002a29-0000-1000-8000-00805f9b34fb
handle: 0x001f, char properties: 0x02, char value handle: 0x0020, uuid: 00002a2a-0000-1000-8000-00805f9b34fb
handle: 0x0021, char properties: 0x02, char value handle: 0x0022, uuid: 00002a50-0000-1000-8000-00805f9b34fb
handle: 0x0024, char properties: 0x12, char value handle: 0x0025, uuid: f000aa21-0451-4000-b000-000000000000
handle: 0x0028, char properties: 0x02, char value handle: 0x0029, uuid: f000aa2f-0451-4000-b000-000000000000
handle: 0x002c, char properties: 0x0a, char value handle: 0x002d, uuid: 00002901-0000-1000-8000-00805f9b34fb
handle: 0x002f, char properties: 0x12, char value handle: 0x0030, uuid: f000aa41-0451-4000-b000-000000000000
handle: 0x0033, char properties: 0x0a, char value handle: 0x0034, uuid: 00002901-0000-1000-8000-00805f9b34fb
handle: 0x0035, char properties: 0x12, char value handle: 0x0036, uuid: f000aa43-0451-4000-b000-000000000000
handle: 0x0039, char properties: 0x02, char value handle: 0x003a, uuid: f000aa4f-0451-4000-b000-000000000000
handle: 0x003e, char properties: 0x12, char value handle: 0x003f, uuid: f0002a19-0451-4000-b000-000000000000
handle: 0x0042, char properties: 0x0a, char value handle: 0x0043, uuid: 00002901-0000-1000-8000-00805f9b34fb
However, according to the datasheet, there are three info missing from the characteristics above, they are:
Data F000AA41-0451-4000-B000-000000000000
Calibration F000AA43-0451-4000-B000-000000000000
Status F000AA4F-0451-4000-B000-000000000000
Wonder if I can get some advice from you.
Best regards,
Jiye
