Testing Serial Devices connected on the USB
Hi All,
I want to run a simple terminal program on the BeagleBoard so I can
check USB devices like USB modems and USB GPS dongles.
I tried to compile minicom but the make fails on several messages
about too many arguments in window.c
My BeagleBoard is not connected to the internet yet so I have come to
the dead end.
Anybody found a way or can suggest a way to check out serial device on
the USB.
MPC.
If you're running Windows, you should be able to use HyperTerminal:
Start->Programs->Accessories->Communications->HyperTerminal
Or, if you're on Linux, you can check if minicom is in your
distributions repositories (probably is). I'm using Ubuntu, which has
minicom pre-compiled in one of the PPA repositories:
sudo aptitude install minicom
