Hi Sir,
Wrong Image Format for bootm command ERROR: can’t get kernel image!
This is my uEnv.txt:
console=ttyO0,115200n8
ipaddr=192.168.27.2
serverip=192.168.27.1
absolutepath=/var/lib/tftpboot/
rootpath=/srv/nfs/bbb,nfsvers=3,tcp ip=dhcp,nolock,wsize=1024,rsize=1024 rootwait rootdelay=5
loadtftp=echo Booting from network …;tftpboot 0x82000000 uImage; tftpboot 0x88000000 am335x-boneblack.dtb
netargs=setenv bootargs console=${console} root=/dev/nfs rw rootfstype=nfs ip=${ipaddr} nfsroot=${serverip}:${rootpath}
uenvcmd=setenv autoload no; setenv ipaddr 192.168.27.2; setenv serverip 192.168.27.1; run loadtftp; run netargs; bootm 0x82000000 - 0x88000000
After loading the uImage and dtb file and then booting the image using bootm command it is giving the error Wrong Image Format for bootm command
When i try to do it manually using bootm command on the uboot prompt it loads but when in the uEnv.txt it shows this error.
Kindly need help
Jennifer
