while board validation doesn't *technically* require poking around
in u-boot, i think there's some value in showing new users what
they're allowed to rummage through if they want to stop the boot
procedure in u-boot and look around. and that's why i think we need
to standardize on a single version of u-boot -- because some of the
commands have changed since the current on-board version, so we might
as well just pick a newer version and go with it. right now, i'm
using the one i built based on the OE dev branch and angstrom, and it
seems to work just fine:
OMAP3 beagleboard.org # version
U-Boot 2009.08 (Nov 26 2009 - 20:30:10)
but i'm open to whatever fairly new and identifiable version people
suggest.
another reason to introduce u-boot (at least briefly) is that, if
the validation procedure fails, at least users will understand what it
means if you ask them to go to u-boot and do some debugging. (will
the upcoming C4 version have a newer u-boot? i would have assumed
so.)
so for the above version of u-boot, i can see telling users to run
(some of which i've already listed at
http://code.google.com/p/beagleboard/wiki/BeagleboardRevCValidationv2):
# version
# bdinfo
# coninfo
# printenv
# nand info
# i2c probe
# mtdparts
# mtest
# mmc(?)
and note that some of these commands (or their output) have changed
since the feb 2009 version. for example, "iprobe" is now "i2c probe",
which is why it would be nice to standardize on a newer u-boot for
everyone and not try to work with two different versions.
(no one's suggesting that users *need* to run any of the above for
the purposes of validation. but people are just curious.)
and now, the obvious questions and digging a bit deeper. first, are
there any other useful informative commands a user might want to
run? feel free to toss out suggestions.
next, we have a curious change in the output of "nand info".
the old version of "nand info":
OMAP3 beagleboard.org # nand info
Device 0: NAND 256MiB 1,8V 16-bit, sector size 128 KiB
the new version of "nand info":
Device 0: nand0, sector size 128 KiB
i'm curious -- why did "nand info" stop printing the device size? i
would have thought that would be useful info.
next, i'm still working my way through i2c, so what can one do with
this output from "i2c probe"?
OMAP3 beagleboard.org # i2c probe
Valid chip addresses: 48 49 4A 4B
given that output, what *further* probing would be informative?
specifically, what's the incantation to check the EDID of a connected
flat-panel display?
and there's perhaps poking around the MMC info:
OMAP3 beagleboard.org # mmc init
mmc1 is available
OMAP3 beagleboard.org # fatls mmc 1
20392 mlo
184316 u-boot.bin
7999649 ramdisk.gz
2578044 uimage.bin
603 boot.scr
files/
5 file(s), 1 dir(s)
so, again, what other u-boot commands would be educational for new
users?
rday
