the opengl-es problem with qt
Hi:
I have some question when enabling opengl-es with Qt on beagleboard; I have compiled the opengl-es and Qt correctly; The test command of the opengl-es also run correctly;
And the content of the file /etc/power.ini is like this:
[default]
WindowSystem=libpvrQWSWSEGL.so
I have write one class GLWidget which inherit from QGLWidget; Also do some draw action in the paintGL();
If I show the glwidget like this:
GLWidget glwidget;
glwidget->showMaximized();
there is no display error;
But when I show like this:
GLWidget glwidget;
glwidget ->show();
It show some vertical lines on the screen;
It means that if it show with fullscreen,there is no problem. Or, it have the display problem mentioned above(show some vertical lines on the screen)
Thanks;
E-mail:Ke.Zou@Plenware.com
