This topic needs a title
This series of patches provides support for Aptina mt9p031 sensor on Beagleboard xM.
It has been tested using media-ctl and yavta.
It has been tested in beagleboard xM, using LI-5M03 module.
Signed-off-by: Javier Martin <javier.martin@vista-silicon.com>
Hi Javier,
Thanks for the patch.
[snip]
diff --git a/drivers/media/video/mt9p031.c b/drivers/media/video/mt9p031.c
new file mode 100644
index 0000000..850cfec
--- /dev/null
+++ b/drivers/media/video/mt9p031.c
@@ -0,0 +1,773 @@
+ * Driver for MT9P031 CMOS Image Sensor from Aptina
+ * Based on the MT9V032 driver and Bastian Hecht's code.
+ * This program is free software; you can redistribute it and/or modify
+ * it under the terms of the GNU General Public License version 2 as
+ * published by the Free Software Foundation.
+#include <linux/delay.h>
+#include <linux/device.h>
+#include <linux/i2c.h>
+#include <linux/log2.h>
+#include <linux/pm.h>
+#include <linux/regulator/consumer.h>
+#include <linux/slab.h>
+#include <media/v4l2-subdev.h>
+#include <linux/videodev2.h>
+#include <media/mt9p031.h>
+#include <media/v4l2-chip-ident.h>
+#include <media/v4l2-device.h>
+/* mt9p031 selected register addresses */
+#define MT9P031_CHIP_VERSION 0x00
+#define MT9P031_CHIP_VERSION_VALUE 0x1801
+#define MT9P031_ROW_START 0x01
+#define MT9P031_ROW_START_SKIP 54
+#define MT9P031_COLUMN_START 0x02
+#define MT9P031_COLUMN_START_SKIP 16
+#define MT9P031_WINDOW_HEIGHT 0x03
+#define MT9P031_WINDOW_WIDTH 0x04
+#define MT9P031_H_BLANKING 0x05
+#define MT9P031_H_BLANKING_VALUE 0
+#define MT9P031_V_BLANKING 0x06
+#define MT9P031_V_BLANKING_VALUE 25
+#define MT9P031_OUTPUT_CONTROL 0x07
+#define MT9P031_OUTPUT_CONTROL_CEN 2
+#define MT9P031_OUTPUT_CONTROL_SYN 1
+#define MT9P031_SHUTTER_WIDTH_UPPER 0x08
+#define MT9P031_SHUTTER_WIDTH 0x09
+#define MT9P031_PIXEL_CLOCK_CONTROL 0x0a
+#define MT9P031_FRAME_RESTART 0x0b
+#define MT9P031_SHUTTER_DELAY 0x0c
+#define MT9P031_RESET 0x0d
+#define MT9P031_RESET_ENABLE 1
+#define MT9P031_RESET_DISABLE 0
+#define MT9P031_READ_MODE_1 0x1e
+#define MT9P031_READ_MODE_2 0x20
+#define MT9P031_READ_MODE_2_ROW_MIR 0x8000
+#define MT9P031_READ_MODE_2_COL_MIR 0x4000
+#define MT9P031_ROW_ADDRESS_MODE 0x22
+#define MT9P031_COLUMN_ADDRESS_MODE 0x23
+#define MT9P031_GLOBAL_GAIN 0x35
+#define MT9P031_MAX_HEIGHT 1944
+#define MT9P031_MAX_WIDTH 2592
+#define MT9P031_MIN_HEIGHT 2
+#define MT9P031_MIN_WIDTH 18
+struct mt9p031 {
+ struct v4l2_subdev subdev;
+ struct media_pad pad;
+ struct v4l2_rect rect; /* Sensor window */
+ struct v4l2_mbus_framefmt format;
+ struct mt9p031_platform_data *pdata;
+ int model; /* V4L2_IDENT_MT9P031* codes from v4l2-chip-ident.h */
model is assigned by never read, you can remove it.
+ u16 xskip;
+ u16 yskip;
+ struct regulator *reg_1v8, *reg_2v8;
Please split this on two lines.
You never enable the 1.8V regulator, is that intentional ?
[snip]
+static int reg_set(struct i2c_client *client, const u8 reg,
+ const u16 data)
+ int ret;
+ ret = reg_read(client, reg);
+ if (ret < 0)
+ return ret;
+ return reg_write(client, reg, ret | data);
+static int reg_clear(struct i2c_client *client, const u8 reg,
+ const u16 data)
+ int ret;
+ if (ret < 0)
+ return ret;
+ return reg_write(client, reg, ret & ~data);
I still think you should use a shadow copy of the register in the mt9p031
structure instead of reading the value back from the hardware. As these two
functions are only used to handle the output control register, you could
create an mt9p031_set_output_control(struct mt9p031 *mt9p031, u16 clear, u16
set) function instead.
+static int mt9p031_idle(struct i2c_client *client)
This function resets the chip, what about calling it mt9p031_reset() instead ?
+ int ret;
+ /* Disable chip output, synchronous option update */
+ ret = reg_write(client, MT9P031_RESET, MT9P031_RESET_ENABLE);
+ if (ret < 0)
+ goto err;
You can return -EIO directly.
+ ret = reg_write(client, MT9P031_RESET, MT9P031_RESET_DISABLE);
+ if (ret < 0)
+ goto err;
Here too.
+ ret = reg_clear(client, MT9P031_OUTPUT_CONTROL,
+ MT9P031_OUTPUT_CONTROL_CEN);
+ if (ret < 0)
+ goto err;
And here too.
+ return 0;
+err:
+ return -EIO;
[snip]
+static int mt9p031_power_on(struct mt9p031 *mt9p031)
+ int ret;
+ if (mt9p031->pdata->set_xclk)
+ mt9p031->pdata->set_xclk(&mt9p031->subdev, 54000000);
+ /* turn on VDD_IO */
+ ret = regulator_enable(mt9p031->reg_2v8);
+ if (ret) {
+ pr_err("Failed to enable 2.8v regulator: %d\n", ret);
+ return -1;
I would enable the regulator first. As a general rule, chips should be powered
up before their I/Os are actively driven.
You need to restore registers here, otherwise all controls set by the user
will not be applied to the device.
+ return 0;
[snip]
+static u16 mt9p031_skip_for_crop(s32 source, s32 *target, s32 max_skip)
+ unsigned int skip;
+ if (source - source / 4 < *target) {
+ *target = source;
+ return 1;
+ skip = DIV_ROUND_CLOSEST(source, *target);
+ if (skip > max_skip)
+ skip = max_skip;
+ *target = 2 * DIV_ROUND_UP(source, 2 * skip);
+ return skip;
+static int mt9p031_set_params(struct i2c_client *client,
+ struct v4l2_rect *rect, u16 xskip, u16 yskip)
set_params should apply the parameters, not change them. They should have
already been validated by the callers.
+ struct mt9p031 *mt9p031 = to_mt9p031(client);
+ int ret;
+ u16 xbin, ybin;
+ const u16 hblank = MT9P031_H_BLANKING_VALUE,
+ vblank = MT9P031_V_BLANKING_VALUE;
+ * TODO: Attention! When implementing horizontal flipping, adjust
+ * alignment according to R2 "Column Start" description in the datasheet
+ if (xskip & 1) {
+ xbin = 1;
+ rect->left &= ~3;
+ } else if (xskip & 2) {
+ xbin = 2;
+ rect->left &= ~7;
+ } else {
+ xbin = 4;
+ rect->left &= ~15;
+ ybin = min(yskip, (u16)4);
+ rect->top &= ~1;
+ /* Disable register update, reconfigure atomically */
+ ret = reg_set(client, MT9P031_OUTPUT_CONTROL,
+ MT9P031_OUTPUT_CONTROL_SYN);
+ if (ret < 0)
+ goto err;
+ dev_dbg(&client->dev, "skip %u:%u, rect %ux%u@%u:%u\n",
+ xskip, yskip, rect->width, rect->height, rect->left, rect->top);
+ /* Blanking and start values - default... */
+ ret = reg_write(client, MT9P031_H_BLANKING, hblank);
+ if (ret < 0)
+ goto err;
+ ret = reg_write(client, MT9P031_V_BLANKING, vblank);
+ if (ret < 0)
+ goto err;
+ if (yskip != mt9p031->yskip || xskip != mt9p031->xskip) {
+ /* Binning, skipping */
+ ret = reg_write(client, MT9P031_COLUMN_ADDRESS_MODE,
+ ((xbin - 1) << 4) | (xskip - 1));
+ if (ret < 0)
+ goto err;
+ ret = reg_write(client, MT9P031_ROW_ADDRESS_MODE,
+ ((ybin - 1) << 4) | (yskip - 1));
+ if (ret < 0)
+ goto err;
+ dev_dbg(&client->dev, "new physical left %u, top %u\n",
+ rect->left, rect->top);
+ ret = reg_write(client, MT9P031_COLUMN_START,
+ rect->left + MT9P031_COLUMN_START_SKIP);
+ if (ret < 0)
+ goto err;
+ ret = reg_write(client, MT9P031_ROW_START,
+ rect->top + MT9P031_ROW_START_SKIP);
+ if (ret < 0)
+ goto err;
+ ret = reg_write(client, MT9P031_WINDOW_WIDTH,
+ rect->width - 1);
+ if (ret < 0)
+ goto err;
+ ret = reg_write(client, MT9P031_WINDOW_HEIGHT,
+ rect->height - 1);
+ if (ret < 0)
+ goto err;
+ /* Re-enable register update, commit all changes */
+ if (ret < 0)
+ goto err;
+ mt9p031->xskip = xskip;
+ mt9p031->yskip = yskip;
+ return ret;
+err:
+ return -1;
+static int mt9p031_set_crop(struct v4l2_subdev *sd,
+ struct v4l2_subdev_fh *fh,
+ struct v4l2_subdev_crop *crop)
+ struct i2c_client *client = v4l2_get_subdevdata(sd);
+ struct mt9p031 *mt9p031 = container_of(sd, struct mt9p031, subdev);
+ struct v4l2_mbus_framefmt *f;
+ struct v4l2_rect *c;
+ u16 xskip, yskip;
+ s32 width, height;
+ int ret;
+ pr_info("%s(%ux%u@%u:%u : %u)\n", __func__,
+ crop->rect.width, crop->rect.height,
+ crop->rect.left, crop->rect.top, crop->which);
+ * Clamp the crop rectangle boundaries and align them to a multiple of 2
+ * pixels.
+ rect.width = ALIGN(clamp(crop->rect.width,
+ MT9P031_MIN_WIDTH, MT9P031_MAX_WIDTH), 2);
+ rect.height = ALIGN(clamp(crop->rect.height,
+ MT9P031_MIN_HEIGHT, MT9P031_MAX_HEIGHT), 2);
+ rect.left = ALIGN(clamp(crop->rect.left,
+ 0, MT9P031_MAX_WIDTH - rect.width), 2);
+ rect.top = ALIGN(clamp(crop->rect.top,
+ 0, MT9P031_MAX_HEIGHT - rect.height), 2);
+ c = mt9p031_get_pad_crop(mt9p031, fh, crop->pad, crop->which);
+ if (rect.width != c->width || rect.height != c->height) {
+ * Reset the output image size if the crop rectangle size has
+ * been modified.
+ f = mt9p031_get_pad_format(mt9p031, fh, crop->pad,
+ crop->which);
+ width = f->width;
+ height = f->height;
+ xskip = mt9p031_skip_for_crop(rect.width, &width, 7);
+ yskip = mt9p031_skip_for_crop(rect.height, &height, 8);
+ } else {
+ xskip = mt9p031->xskip;
+ yskip = mt9p031->yskip;
+ f = NULL;
+ if (crop->which == V4L2_SUBDEV_FORMAT_ACTIVE) {
+ ret = mt9p031_set_params(client, &rect, xskip, yskip);
+ if (ret < 0)
+ return ret;
+ if (f) {
+ f->width = width;
+ f->height = height;
+ *c = rect;
+ crop->rect = rect;
+ return 0;
[snip]
+static u16 mt9p031_skip_for_scale(s32 *source, s32 target,
+ s32 max_skip, s32 max)
+ if (*source - *source / 4 < target) {
+ *source = target;
+ return 1;
+ skip = min(max, *source + target / 2) / target;
+ skip = max_skip;
+ *source = target * skip;
+ return skip;
[snip]
+static int mt9p031_set_format(struct v4l2_subdev *sd,
+ struct v4l2_subdev_format *fmt)
+ struct v4l2_subdev_format sdf = *fmt;
+ struct v4l2_mbus_framefmt *f, *format = &sdf.format;
+ struct v4l2_rect *c, rect;
+ u16 xskip, yskip;
+ int ret;
+ ret = mt9p031_fmt_validate(sd, &sdf);
+ if (ret < 0)
+ return ret;
+ f = mt9p031_get_pad_format(mt9p031, fh, fmt->pad, fmt->which);
+ if (f->width != format->width || f->height != format->height) {
If width and height are identical to the current value, you can return
immediately.
+ c = mt9p031_get_pad_crop(mt9p031, fh, fmt->pad, fmt->which);
+ rect.width = c->width;
+ rect.height = c->height;
+ xskip = mt9p031_skip_for_scale(&rect.width, format->width, 7,
+ MT9P031_MAX_WIDTH);
+ if (rect.width + c->left > MT9P031_MAX_WIDTH)
+ rect.left = (MT9P031_MAX_WIDTH - rect.width) / 2;
+ else
+ rect.left = c->left;
+ yskip = mt9p031_skip_for_scale(&rect.height, format->height, 8,
+ MT9P031_MAX_HEIGHT);
+ if (rect.height + c->top > MT9P031_MAX_HEIGHT)
+ rect.top = (MT9P031_MAX_HEIGHT - rect.height) / 2;
+ else
+ rect.top = c->top;
+ } else {
+ c = NULL;
+ pr_info("%s(%ux%u : %u)\n", __func__,
+ format->width, format->height, fmt->which);
+ if (fmt->which == V4L2_SUBDEV_FORMAT_ACTIVE) {
+ /* mt9p031_set_params() doesn't change width and height */
+ if (ret < 0)
+ return ret;
+ if (c)
+ *c = rect;
+ *f = *format;
+ fmt->format = *format;
+ return 0;
[snip]
+static int mt9p031_registered(struct v4l2_subdev *sd)
+ struct mt9p031 *mt9p031;
+ mt9p031 = container_of(sd, struct mt9p031, subdev);
+ mt9p031_power_off(mt9p031);
What's that for ?
+ return 0;
[snip]
+static int mt9p031_close(struct v4l2_subdev *sd, struct v4l2_subdev_fh
*fh) +{
You need to reference count power handling, otherwise closing the subdev file
handle will turn the power off, even if the sensor is part of a pipeline
actively streaming video. Have a look at the mt9v032 driver to see how that's
done.
+ return 0;
[snip]
+static int mt9p031_probe(struct i2c_client *client,
+ const struct i2c_device_id *did)
+ struct v4l2_subdev *sd = i2c_get_clientdata(client);
+ struct mt9p031_platform_data *pdata = client->dev.platform_data;
+ struct i2c_adapter *adapter = to_i2c_adapter(client->dev.parent);
+ int ret;
+ if (!i2c_check_functionality(adapter, I2C_FUNC_SMBUS_WORD_DATA)) {
+ dev_warn(&adapter->dev,
+ "I2C-Adapter doesn't support I2C_FUNC_SMBUS_WORD\n");
+ return -EIO;
+ mt9p031 = kzalloc(sizeof(struct mt9p031), GFP_KERNEL);
+ if (!mt9p031)
+ return -ENOMEM;
+ v4l2_i2c_subdev_init(&mt9p031->subdev, client, &mt9p031_subdev_ops);
+ mt9p031->subdev.internal_ops = &mt9p031_subdev_internal_ops;
+ mt9p031->pdata = pdata;
+ mt9p031->rect.left = 0/*MT9P031_COLUMN_SKIP*/;
+ mt9p031->rect.top = 0/*MT9P031_ROW_SKIP*/;
No commented out code please.
+ mt9p031->rect.width = MT9P031_MAX_WIDTH;
+ mt9p031->rect.height = MT9P031_MAX_HEIGHT;
+ mt9p031->format.code = V4L2_MBUS_FMT_SGRBG12_1X12;
+ mt9p031->format.width = MT9P031_MAX_WIDTH;
+ mt9p031->format.height = MT9P031_MAX_HEIGHT;
+ mt9p031->format.field = V4L2_FIELD_NONE;
+ mt9p031->format.colorspace = V4L2_COLORSPACE_SRGB;
+ /* mt9p031_idle() will reset the chip to default. */
There's no mt9p032_idle() call here.
+ mt9p031->xskip = 1;
+ mt9p031->yskip = 1;
+ mt9p031->reg_1v8 = regulator_get(NULL, "cam_1v8");
+ if (IS_ERR(mt9p031->reg_1v8)) {
+ ret = PTR_ERR(mt9p031->reg_1v8);
+ pr_err("Failed 1.8v regulator: %d\n", ret);
+ goto e1v8;
+ mt9p031->reg_2v8 = regulator_get(NULL, "cam_2v8");
+ if (IS_ERR(mt9p031->reg_2v8)) {
+ ret = PTR_ERR(mt9p031->reg_2v8);
+ pr_err("Failed 2.8v regulator: %d\n", ret);
+ goto e2v8;
+ ret = mt9p031_power_on(mt9p031);
+ if (ret) {
+ pr_err("Failed to power on device: %d\n", ret);
+ goto pwron;
+ if (ret) {
+ goto e2v8en;
The regulator is enabled by mt9p032_power_on(), there's no need to enable it a
second time herE.
+ if (pdata->reset)
+ pdata->reset(sd, 1);
+ msleep(50);
+ if (pdata->reset)
+ pdata->reset(sd, 0);
+ msleep(50);
Why do you need to reset the chip here ? If resetting it is required after
powering it up, you should do it every time the power is turned on, not just
here.
+ ret = mt9p031_video_probe(client);
You have a set_xclk callback to board code, so I assume the chip can be driven
by one of the OMAP3 ISP XCLK signals. To call back to the OMAP3 ISP from board
code, you need to get hold of the OMAP3 ISP device pointer. Your next patch
exports omap3isp_device, but I'm not sure that's the way to go. One option is
struct isp_device *isp = v4l2_dev_to_isp_device(subdev->v4l2_dev);
but that requires the subdev to be registered before the function can be
called. In that case you would need to move the probe code to the registered
subdev internal function.
A clean solution is needed in the long run, preferably not involving board
code at all. It would be nice if the OMAP3 ISP driver could export XCLKA/XCLKB
as generic clock objects.
+ if (ret)
+ goto evprobe;
+ mt9p031->pad.flags = MEDIA_PAD_FL_SOURCE;
+ ret = media_entity_init(&mt9p031->subdev.entity, 1, &mt9p031->pad, 0);
+ if (ret)
+ goto evprobe;
+ mt9p031->subdev.flags |= V4L2_SUBDEV_FL_HAS_DEVNODE;
+ return ret;
+evprobe:
+ regulator_disable(mt9p031->reg_2v8);
+e2v8en:
+pwron:
+ regulator_put(mt9p031->reg_2v8);
+e2v8:
+ regulator_put(mt9p031->reg_1v8);
+e1v8:
+ kfree(mt9p031);
+ return ret;
[snip]
+MODULE_DESCRIPTION("Aptina MT9P031 Camera driver");
You mention Micron in the Kconfig file, maybe you could replace it with
Aptina.
+MODULE_AUTHOR("Bastian Hecht <hechtb@gmail.com>");
+MODULE_LICENSE("GPL v2");
[snip]
diff --git a/include/media/v4l2-chip-ident.h
b/include/media/v4l2-chip-ident.h index b3edb67..97919f2 100644
--- a/include/media/v4l2-chip-ident.h
+++ b/include/media/v4l2-chip-ident.h
@@ -297,6 +297,7 @@ enum {
   V4L2_IDENT_MT9T112 = 45022,
   V4L2_IDENT_MT9V111 = 45031,
   V4L2_IDENT_MT9V112 = 45032,
+ V4L2_IDENT_MT9P031 = 45033,
This constant will become unused, you can remove it as well.
Hi Laurent
Thanks for your review! Javier, if you like, you can wait a couple of days
until I find some time to review the driver, or you can submit a version,
addressing Laurent's points, but be prepared to have to do another one;)
Guennadi
OK, I think I'll wait to have Guennadi's review too.
Thank you both.
Javier,
I have been using the aptina patch (https://github.com/Aptina/BeagleBoard-xM) on beagleboard while waiting linux-media solve this mt9p031 issue. Now that you have something working, I would like to try it - but I would like to know what is the clock rate you actually drove the sensor.
Reviewing your path, I suppose it is 54MHz, so you would be achieving some 10 full 5MPix frames/s from the sensor. Is that correct? (the aptina patch delivers less than 4 fps).
Ivan
+#include "devices.h"
+#include "../../../drivers/media/video/omap3isp/isp.h"
+#include "../../../drivers/media/video/omap3isp/ispreg.h"
This suggests that there's something very wrong with what's going on;
it suggests that you're trying to access driver internals which should
be handled via some better means. And it looks like it's this:
@@ -654,6 +715,62 @@ static void __init beagle_opp_init(void)
   return;
+extern struct platform_device omap3isp_device;
+static int beagle_cam_set_xclk(struct v4l2_subdev *subdev, int hz)
+ struct isp_device *isp = platform_get_drvdata(&omap3isp_device);
+ int ret;
+ ret = isp->platform_cb.set_xclk(isp, hz, MT9P031_XCLK);
+ return 0;
That really needs fixing in a different way.
Hi Javier,
Sorry, but this laziness is getting beyond a joke... And the fact that
apparantly no one is picking up on it other than me is also a joke.
> + int ret;
> + if (ret) {
> + return -1;
And why all these 'return -1's? My guess is that this is plain laziness
on the authors part.
> +err:
> + return -1;
And again...
> + if (ret < 0)
> + return ret;
So this propagates the lazy 'return -1' all the way back to userspace.
This is utter crap - really it is, and I'm getting sick and tired of
telling people that they should not use 'return -1'. It's down right
lazy and sloppy programming.
I wish people would stop doing it. I wish people would review their own
stuff for this _before_ posting it onto a mailing list, so I don't have
to keep complaining about it. And I wish people reviewing drivers would
also look for this as well and complain about it.
'return -1' is generally a big fat warning sign that the author is doing
something wrong, and should _always_ be investigated and complained about.
Hi Russell,
Hi Laurent,
I've already fixed almost every issue you pointed out.
However, I still have got some doubts that I hope you can clarify.
Hi Javier,
+ int ret;
+ if (ret) {
+ return -1;
It's my mistake. This driver uses two regulators: 1,8 and 2,8 V
respectively. 2,8V regulator powers analog part and I/O whereas 1,8V
one powers the core. What I failed to do was keeping 1,8V regulator
always powered on, so that register configuration was not lost, and
power 2,8V regulator on and off as needed since it does not affect
register values. However, I messed it all up.
Ideally I would have to power 1,8V regulator on and off too. However,
as you wisely pointed out, registers should be restored in that case.
How am I supposed to keep track of register values? Are there any
helper functions I can use for that purpose or must I create a custom
register cache? Do you know any driver that uses this technique?
[snip]
"mt9p031_set_params()" function is used by "mt9p031_set_crop()" and
"mt9p031_set_format()", as you have correctly stated, these functions
shouldn' apply parameters but only change them.
I've checked mt9v032 driver and it is as you said. The question is,
where should these parameters get applied then?
What's that for ?
+ return 0;
Since "mt9p031_power_off()" and "mt9p031_power_on()" functions
disable/enable the 2,8V regulator which powers I/O, it must be powered
on during probe and after registering, it can be safely powered off.
Yes, I tried using that function but it didn't work because subdev
hadn't been registeret yet.
So, what should I do in order to submit the driver to mainline?
Do you want me to move the probe code to registered callback?
Thank you.
Hi Ivan,
Hi Javier,
Hi Laurent,
>> + int ret;
>> + if (ret) {
>> + return -1;
>powered up before their I/Os are actively driven.
You can either keep track of register contents manually, or use the control
framework to restore the value of all controls by calling
v4l2_ctrl_handler_setup(). That's what the mt9v032 driver does in its power on
handler. You might have to restore a couple of registers manually if they're
not handled through controls.
> [snip]
>> yskip)
The mt9v032 driver applies those parameters at stream on time. The downside is
that it doesn't support resolution or crop changes at runtime. While changing
resolution at runtime might not make much sense in most cases, changing the
crop rectangle (providing its size stays the same) is a useful feature.
You can handle resolution changes at runtime, or you can choose to only set
the resolution at stream on time. In both cases, the mt9p031_set_params()
function should only apply parameters to the device, not change their value on
the driver side. That was the purpose of my original comment.
> What's that for ?
>> + return 0;
Can't you just power it off at the end of your probe function, instead of
doing it here ?
> driven by one of the OMAP3 ISP XCLK signals. To call back to the OMAP3
> ISP from board code, you need to get hold of the OMAP3 ISP device
> pointer. Your next patch exports omap3isp_device, but I'm not sure
> registered subdev internal function.
> board code at all. It would be nice if the OMAP3 ISP driver could export
> XCLKA/XCLKB as generic clock objects.
You should move the part that powers the device up and reads registers to the
registered callback. The board code should then use v4l2_dev_to_isp_device()
as showed above. This isn't a perfect solution, but at least it will be
consistent with other sensor drivers. When the OMAP3 ISP clocks will be
available through the clock framework, we will fix board code (and possibly
sensor drivers).
what’s this?
static struct i2c_board_info __initdata beagle_i2c_eeprom[] = {
  • I2C_BOARD_INFO(“eeprom”, 0x50),
2011/5/18 Laurent Pinchart <laurent.pinchart@ideasonboard.com>
