I have been stepping through my javascript code that does not work and I end up in the file: bonescript.js, and more specifically in this function:
function require(file) { throw 'Please perform setTargetAddress on a valid target'; }
This happens when I try to call:
var b = require('bonescript');
To try to solve the problem I stepped through some examples and noticed I that code brought me to a completely different “bonescript.js” file.
Turns out there are three:
/usr/share/bone101/static/bonescript.js
/usr/share/beaglebone-getting-started/Docs/bonescript.js
/usr/lib/node_modules/bonescript/bonescript.js
Can someone shed some light on this?
John
that code brought me to a completely different "bonescript.js" file.
That one is used to establish a connection with the board from a
remote web page. It is served up at
http://YOUR_BEAGLEBONE/static/bonescript.js
That has a somewhat similar purpose, but is used in the Getting
Started Guide served up on the FAT partition.
This is the one that performs the socket.io connection services and is
served up at http://YOUR_BEAGLEBONE/beaglebone.js by server.js.
The actual bonescript functions are defined in
/usr/lib/node_modules/bonescript/index.js
