So what do I need to do to get the most basic c program to output anything?
#include<stdio.h>
int main()
printf(“hello world”);
compile with gcc
output: nada, nowt, zilch…
This thing sure has a steep learning curve…
(running Angstrom)
#include<stdio.h>
int main()
compile with gcc
(running Angstrom)
First, you need to SSH to your board and login as root.
#include <stdio.h>
int main(void){
printf(“Hello World\n”);
return 0;
3) In the terminal, type $ g++ example.c -o example
4) Finally, type ./example
5) You should see an output of “Hello World” on your screen.
Once compiled, you should have an executable file (a.out unless you change it with the -o option to gcc). Type in “./a.out” and press enter, and it should give you the output you’re looking for.
Lets suppose you have a file called hello.c
Just me being daft…
I used a file name called test,
test is obviously used elsewhere for something and whatever it does, nothing is returned to the console.
./test actually runs my program, which works perfectly of course!!!
Now on to more interesting things…
Thanks for your input, I thought I was going mad!
