TI Kernel update hang
I have two pretty much identical blacks that I regularly update using the update_kernel.sh script.
Have just updated from v3.14.35-ti-r56 to v3.14.37-ti-r57. The first bone rebooted as normal, whereas the
second now hangs (output from serial console), anyone any ideas what might have gone wrong?
SD/MMC found on device 0
reading uEnv.txt
681 bytes read in 3 ms (221.7 KiB/s)
Running uenvcmd …
349 bytes read in 23 ms (14.6 KiB/s)
7065064 bytes read in 1182 ms (5.7 MiB/s)
3878256 bytes read in 662 ms (5.6 MiB/s)
87125 bytes read in 105 ms (809.6 KiB/s)
Flattened Device Tree blob at 80f80000
Booting using the fdt blob at 0x80f80000
Loading Ramdisk to 9ee84000, end 9f236d70 … OK
Using Device Tree in place at 80f80000, end 80f98454
Starting kernel …
Looks like things went off the edge ^^, lets first look at uEnv.txt
and double check:
loadaddr=0x82000000
fdtaddr=0x88000000
rdaddr=0x88080000
debug: [bootz 0x82000000 0x88080000:38a2f4 0x88000000] ...
Kernel image @ 0x82000000 [ 0x000000 - 0x6c49f8 ]
## Flattened Device Tree blob at 88000000
   Loading Ramdisk to 8fc75000, end 8ffff2f4 ... OK
   Loading Device Tree to 8fc5c000, end 8fc74454 ... OK
