From ca6c186c40fafaf0bf53f5f3e90057c0a34374f9 Mon Sep 17 00:00:00 2001
Date: Mon, 18 Jan 2010 18:22:09 +0530
Subject: [PATCH] API to set twl4030 voltage and dev groupV3:
Incorporated review comments to set voltage first
and then dev groupV2:
Incorporated review comments to split the patch and
add generic API to set the voltage and device group.
[U-Boot] TI:OMAP: [PATCH 3/4] Support 720Mhz configuration for OMAP35xxV1:
Added support for 720 Mhz
Re: [U-Boot] TI:OMAP: [ PATCH 2/4 ] Configure PRCM registers to support 720 MhzSigned-off-by: Syed Mohammed Khasim <khasim@ti.com>
drivers/power/twl4030.c | 24 +++++++++++++++---------
include/twl4030.h | 16 ++++++++++++++++
2 files changed, 31 insertions(+), 9 deletions(-)diff --git a/drivers/power/twl4030.c b/drivers/power/twl4030.c
index eb066cb..f25b58f 100644
--- a/drivers/power/twl4030.c
+++ b/drivers/power/twl4030.c
@@ -59,16 +59,9 @@ void twl4030_power_reset_init(void)
* Power Init
-#define DEV_GRP_P1 0x20
-#define VAUX3_VSEL_28 0x03
-#define DEV_GRP_ALL 0xE0
-#define VPLL2_VSEL_18 0x05
-#define VDAC_VSEL_18 0x03
void twl4030_power_init(void)
unsigned char byte;
@@ -98,8 +91,6 @@ void twl4030_power_init(void)
TWL4030_PM_RECEIVER_VDAC_DEDICATED);
}-#define VMMC1_VSEL_30 0x02
void twl4030_power_mmc_init(void)
unsigned char byte;
@@ -113,3 +104,18 @@ void twl4030_power_mmc_init(void)
twl4030_i2c_write_u8(TWL4030_CHIP_PM_RECEIVER, byte,
TWL4030_PM_RECEIVER_VMMC1_DEDICATED);
+ * Generic function to select Device Group and Voltage
+void twl4030_pmrecv_vsel_cfg(u8 vsel_reg, u8 vsel_val,
+ u8 dev_grp, u8 dev_grp_sel)
+ /* Select the Voltage */
+ twl4030_i2c_write_u8(TWL4030_CHIP_PM_RECEIVER, vsel_val,
+ vsel_reg);
+ /* Select the Device Group */
+ twl4030_i2c_write_u8(TWL4030_CHIP_PM_RECEIVER, dev_grp_sel,
+ dev_grp);
diff --git a/include/twl4030.h b/include/twl4030.h
index 2b2f5ae..9bdd3ea 100644
--- a/include/twl4030.h
+++ b/include/twl4030.h
@@ -471,6 +471,22 @@
#define TWL4030_USB_PHY_CLK_CTRL_STS 0xFF/*
+ * Voltage Selection in PM Receiver Module
+#define VAUX2_VSEL_18 0x05
+#define VDD1_VSEL_14 0x40
+#define VAUX3_VSEL_28 0x03
+#define VPLL2_VSEL_18 0x05
+#define VDAC_VSEL_18 0x03
+#define VMMC1_VSEL_30 0x02
Remain consistent with existing naming
Use the TWL4030_PM_RECEIVER prefix
Tom
Are you sure, you want to do this
VMMC1_VSEL_30
Changed to
TWL4030_PM_RECEIVER_VMMC1_VSEL_30
It looks very awkward to me, More over the prefix is used for register
definition already. This is bit value - Kindly confirm
Khasim
* Power Init
unsigned char byte;
unsigned char byte;
+ vsel_reg);
+ dev_grp);
+Remain consistent with existing naming
Use the TWL4030_PM_RECEIVER prefixAre you sure, you want to do this
VMMC1_VSEL_30
Changed to
Yes
The goal is to be consistent.
Tom
