TIDL Classification example not properly identify objects
I am attempting to run the TIDL example with a Beaglebone AI and the only thing it seems to report identifying is a ping-pong, although I am not presenting a ping pong to the camera. I am using a Logitech C920 camera and have performed all of the updates to the system, so am not sure what I am missing.
This is what I see when running the classification.tidl.cpp example:
sudo mjpg_streamer -i "input_opencv.so -r 640x480 --filter ./classification.tidl.so" -o "output_http.so -p 8080 -w /usr/share/mjpg-streamer/www" [sudo] password for debian: MJPG Streamer Version.: 2.0 i: device........... : default i: Desired Resolution: 640 x 480 i: filter........... : ./classification.tidl.so i: filter args ..... : Initializing filter loading configuration allocating execution object pipelines (EOP) allocating executors allocating individual EOPs allocating I/O memory for each EOP Allocating input and output buffers Allocating input and output buffers Allocating input and output buffers Allocating input and output buffers num_eops=4 About to start ProcessFrame loop!! http://localhost:8080/?action=stream o: www-folder-path......: /usr/share/mjpg-streamer/www/ o: HTTP TCP port........: 8080 o: HTTP Listen Address..: (null) o: username:password....: disabled o: commands.............: enabled (722)=ping-pong_ball (722)=ping-pong_ball (722)=ping-pong_ball (722)=ping-pong_ball (722)=ping-pong_ball (722)=ping-pong_ball
This is what I see from dmesg:
[20753.769040] usb 1-1: New USB device found, idVendor=046d, idProduct=082d
[20753.769075] usb 1-1: New USB device strings: Mfr=0, Product=2, SerialNumber=1
[20753.769097] usb 1-1: Product: HD Pro Webcam C920
[20753.769118] usb 1-1: SerialNumber: C0DB0F6F
[20754.099831] uvcvideo: Found UVC 1.00 device HD Pro Webcam C920 (046d:082d)
[20754.120146] uvcvideo 1-1:1.0: Entity type for entity Processing 3 was not initialized!
[20754.120179] uvcvideo 1-1:1.0: Entity type for entity Extension 6 was not initialized!
[20754.120323] uvcvideo 1-1:1.0: Entity type for entity Extension 11 was not initialized!
[20754.125089] input: HD Pro Webcam C920 as /devices/platform/44000000.ocp/488c0000.omap_dwc3_2/488d0000.usb/xhci-hcd.1.auto/usb1/1-1/1-1:1.0/input/input3
[20754.135851] usbcore: registered new interface driver uvcvideo
[20754.135871] USB Video Class driver (1.1.1)
[20754.437849] usbcore: registered new interface driver snd-usb-audio
[20867.134498] usb 1-1: reset high-speed USB device number 3 using xhci-hcd
[20867.558788] omap-iommu 58882000.mmu: 58882000.mmu: version 2.1
[20867.605127] omap_hwmod: mmu0_dsp2: _wait_target_disable failed
[20867.605206] omap-iommu 41501000.mmu: 41501000.mmu: version 3.0
[20867.605483] omap-iommu 41502000.mmu: 41502000.mmu: version 3.0
[20867.619103] omap_hwmod: mmu0_dsp1: _wait_target_disable failed
Am I missing a step?
Cheers,
Jon
In my case I also see often ping-pong_ball, or more often “segmentation fault”.
I wonder how can I debug this?
Yeah, I always find it suspect when am example is posted and demo’d but does not seem to work for others.
Headbanging continues.
Jon
Sorry about that. I broke the example. I’ve updated it and it should work now.
https://github.com/beagleboard/cloud9-examples/commit/210388017fcb233c2f422d54af293bb8d5c94bc2
I was visiting the TI office and talking to the developers about the performance of this example. According to profiles,
it should run up to 60fps. I attempted to make some changes to speed it up, but I did it wrong.
You can group different layers in the network to run on different processors. For this classifier network, it is said to
be fastest to run the first 11 stages on EVEs as fixed-point processes and then run the last 3 layers as floating-point
processes on the C66 DSPs. And, because we’d only be running 3 layers on the DSPs, we only need a single DSP.
Anyway, I didn’t assign the layers properly and I still need to look at the code a bit more to set them properly.
For now, I’ve just switched back to running on all 14 layers on 4 EVEs. The 30fps data from the camera seems to
be reasonably processed with this configuration.
I picked up a Logitech C922 that is capable of doing 60fps and I’ll be looking to update the demo to run that way soon
and finishing up the segmentation demo.
Checking the commit-log is a nice way to check-up on me, even if my comments aren’t the best.
The errors are mostly due to the fact that I’m learning as well. I’m trying to get the TI developers to use my methodology
of single-file mjpg-streamer filters rather then OpenCV desktop apps as I feel those the desktop apps are overly complex
and don’t represent an embedded developer’s use-case. They are pretty reasonably documented,
but, as you can see, it is taking me some time to understand them. Some additional debug visibility needs to be added
to my approach and I’ll be chatting to the TI developers about that some in my call later today about this stuff.
Development work is on-going for Tensorflow Lite support. All should be much easier once that lands.
And, yes, I keep talking about TI as if I don’t work there, and I do work there, but my working with open source
developers all day keeps me from adopting certain development processes other TI developers take as granted.
I don’t install Code Composer Studio. I don’t setup an Open Embedded build environment. I don’t cross-compile.
I don’t setup JTAG. I hope you get the idea.
Jason,
I appreciate the update. I’ll update the code on me BB AI and run the exercise again.
Now to get the blinkLED.py and JavaScript examples working.
I’m looking forward for the Tensorflow Lite support, so I’ll keep and eye on that.
Thanks for the work you do on this.
Cheers,
Jon
I’ve pulled in the changes but now I get the following error when attempting to run the TIDL example from the Cloud9 IDE.
NOTE: I’ve updated to the 4.19 kernel, so I am not sure if that is causing the issue:
Command: BeagleBone/AI/tidl/classification.tidl.cpp
Python: python3
Python path: /usr/lib/python3.7/dist-packages:/usr/local/lib/python3.7/dist-packages
/var/lib/cloud9/common/Makefile:27: MODEL=BeagleBoard.org_BeagleBone_AI,TARGET=classification.tidl,COMMON=/var/lib/cloud9/common
/var/lib/cloud9/common/Makefile:145: GEN_DIR=/tmp/cloud9-examples,CHIP=am57xx,PROC=tidl,PRUN=,PRU_DIR=,EXE=.so
ti-mct-heap-check -c
sudo mjpg_streamer -i “input_opencv.so -r 640x480 --filter ./classification.tidl.so” -o “output_http.so -p 8080 -w /usr/share/mjpg-streamer/www”
i: device… : default
i: filter… : ./classification.tidl.so
i: filter args … :
Initializing filter
CMEM Error: init: major version mismatch between interface and driver.
CMEM Error: needs driver version 0x4150002, got 0x4160000
TIOCL FATAL: The cmemk kernel module is not installed. Consult the OpenCL UserGuide at http://software-dl.ti.com/mctools/esd/docs/opencl/index.html
/var/lib/cloud9/common/Makefile:167: recipe for target ‘start’ failed
make: *** [start] Error 1
Cheers,
Jon
Thank you, Jason.
Applying the changes made the classification demo reliably working.
No crashes.
Dobrin
I get the same error as well. Updated everything and rebooted a couple of times.
Dobrin,
Are you running the 4.14 or 4.19 kernel?
Cheers,
Jon
debian@beaglebone:/var/lib/cloud9$ uname -r
4.14.108-ti-r119
Stick to 4.14.
Provide me the output of:
cd /var/lib/cloud9;git status;git show | head -1
Thanks. Reverted back to 4.14 and the classification.cpp example is working. Still fighting to get PWM and a GPIO input to work, though, with bonescript.
This is the output of the commands you requested. Note, i did make some changes to workaround some of the issues.
debian@beaglebone:/var/lib/cloud9$ git status
On branch master
Your branch is up-to-date with ‘origin/master’.
Changes not staged for commit:
(use “git add …” to update what will be committed)
(use “git checkout – …” to discard changes in working directory)
modified: BeagleBone/AI/analogInOut.js
modified: BeagleBone/AI/blinkLED.js
modified: BeagleBone/AI/blinkLED.py
Untracked files:
(use “git add …” to include in what will be committed)
no changes added to commit (use “git add” and/or “git commit -a”)
debian@beaglebone:/var/lib/cloud9$ git show | head -1
commit 40f82013c3a27e4fc7e3604da3cd53b3ce05706d
Cheers,
Jon
Any luck finishing up the segmentation demo?? This completed example would be perfect for converting SSD_multibox. Thank you.
