I’m trying to get a custom cape with LCD up & running with the 4.14LTS LXQT image “http://debian.beagleboard.org/images/bone-debian-9.5-lxqt-armhf-2018-10-07-4gb.img.xz”
The dtbo I’m using works fine on an old image, 3.8.13 but not on the newer 4.14 - are there changes I need to make?
It seems it doesn’t find the the LCD port?
Why? How can I get it to see the LCD?
James
The log from the serial port is:
U-Boot 2018.09-00002-g0b54a51eee (Sep 10 2018 - 19:41:39 -0500), Build: jenkins-github_Bootloader-Builder-65
CPU : AM335X-GP rev 2.1
I2C: ready
DRAM: 512 MiB
No match for driver ‘omap_hsmmc’
Some drivers were not found
RTC 32KCLK Source: External.
Loading Environment from EXT4… ** File not found /boot/uboot.env **
** Unable to read “/boot/uboot.env” from mmc0:1 **
Board: BeagleBone Black
not set. Validating first E-fuse MAC
BeagleBone Black:
debug: process_cape_part_number:[BB-BONE-Mita-00.]
debug: fixup, extra . in eeprom field
debug: process_cape_part_number:[42422D424F4E452D4D6974612D3030]
BeagleBone: cape eeprom: i2c_probe: 0x54: /lib/firmware/BB-BONE-Mita-00-00A0.dtbo [0xfe4416f]
BeagleBone: cape eeprom: i2c_probe: 0x55:
BeagleBone: cape eeprom: i2c_probe: 0x56:
BeagleBone: cape eeprom: i2c_probe: 0x57:
Net: eth0: MII MODE
cpsw, usb_ether
Press SPACE to abort autoboot in 2 seconds
board_name=[A335BNLT] …
board_rev=[00C0] …
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Scanning mmc 0:1…
Checking for: /uEnv.txt …
Checking for: /boot.scr …
Checking for: /boot/boot.scr …
Checking for: /boot/uEnv.txt …
2405 bytes read in 45 ms (51.8 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt…
Running uname_boot …
loading /boot/vmlinuz-4.14.71-ti-r80 …
10416640 bytes read in 869 ms (11.4 MiB/s)
debug: [enable_uboot_overlays=1] …
debug: [enable_uboot_cape_universal=] …
debug: [uboot_base_dtb_univ=am335x-boneblack-uboot.dtb] …
uboot_overlays: [uboot_base_dtb=am335x-boneblack-uboot.dtb] …
uboot_overlays: Switching too: dtb=am335x-boneblack-uboot.dtb …
loading /boot/dtbs/4.14.71-ti-r80/am335x-boneblack-uboot.dtb …
58048 bytes read in 45 ms (1.2 MiB/s)
uboot_overlays: [fdt_buffer=0x60000] …
uboot_overlays: loading /lib/firmware/BB-UART1-00A0.dtbo …
1075 bytes read in 497 ms (2 KiB/s)
uboot_overlays: loading /lib/firmware/BB-UART2-00A0.dtbo …
1075 bytes read in 628 ms (1000 Bytes/s)
uboot_overlays: loading /lib/firmware/BB-UART4-00A0.dtbo …
1075 bytes read in 744 ms (1000 Bytes/s)
uboot_overlays: loading /lib/firmware/BB-BONE-Mita-00-00A0.dtbo …
6211 bytes read in 476 ms (12.7 KiB/s)
uboot_overlays: loading /lib/firmware/BB-BONE-eMMC1-01-00A0.dtbo …
1440 bytes read in 622 ms (2 KiB/s)
uboot_overlays: uboot loading of [/lib/firmware/BB-HDMI-TDA998x-00A0.dtbo] disabled by /boot/uEnv.txt [disable_uboot_overlay_video=1]…
uboot_overlays: loading /lib/firmware/BB-ADC-00A0.dtbo …
711 bytes read in 519 ms (1000 Bytes/s)
uboot_overlays: [uboot_detected_capes=BB-BONE-Mita-00,] …
uboot_overlays: add [enable_uboot_cape_universal=1] to /boot/uEnv.txt to enable…
loading /boot/initrd.img-4.14.71-ti-r80 …
5006883 bytes read in 426 ms (11.2 MiB/s)
debug: [console=ttyO0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait uboot_detected_capes=BB-BONE-Mita-00, coherent_pool=1M net.ifnames=0 quiet] …
debug: [bootz 0x82000000 0x88080000:4c6623 88000000] …
Loading Ramdisk to 8fb39000, end 8ffff623 … OK
reserving fdt memory region: addr=88000000 size=70000
Loading Device Tree to 8fac6000, end 8fb38fff … OK
Starting kernel …
[ 0.000804] timer_probe: no matching timers found
[ 1.069985] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 1.096154] OF: graph: no port node found in /ocp/fb
[ 1.101450] OF: graph: no port node found in /ocp/fb
[ 1.107453] OF: graph: no port node found in /ocp/fb
[ 1.112489] tilcdc 4830e000.fb: no encoders/connectors found
[ 1.366722] omap_voltage_late_init: Voltage driver support not added
[ 1.373815] PM: Cannot get wkup_m3_ipc handle
rootfs: recovering journal
rootfs: clean, 160158/483840 files, 941509/1939456 blocks
Debian GNU/Linux 9 beaglebone ttyS0
BeagleBoard.org Debian Image 2018-10-07
Support/FAQ: http://elinux.org/Beagleboard:BeagleBoneBlack_Debian
The /boot/uEnv.txt is as follows:
uname_r=4.14.71-ti-r80
#uuid=
#dtb=
###U-Boot Overlays###
###Documentation: http://elinux.org/Beagleboard:BeagleBoneBlack_Debian#U-Boot_Overlays
###Master Enable
