@John Syne:
Correct, remoteproc is stabil since month. Stabil in the point that it isn’t usable. And that’s why it is and it should be experimental. And experimental features shouldn’t polute the main stream images!
I don’t agree, remoteproc framework has undergone changes, but these changes didn’t result in significant changes to the example code so user code was easily updated when upgrading to a newer version of remoteproc. With your thinking, Devicetree shouldn’t be in mainline either.
@Jason Reeder and Suman Anna:
Thanks for joining that discussion and for sharing your project. You defined big targets, unfortunatelly you forget about the basics. Following your current concept, prussdrv can never get replaced by your solution.
One reason is execution speed. It might be suitable for BeagleLogic, which uses minimal communication between ARM and PRUs before and after the measurement, in non-time critical situations. In contrast, my project libpruio is designed to work in the main controller loop. Everyting is time critical here. Therefor I use a messaging system simmilar to the one in RPMsg, but highly speed optimized. Just one example: In order to send a message from ARM to PRU, if I’d switch to RPMsg, I’d have to use function pru_rpmsg_send() for that purpose. Just the preparation of that function call (five parameters on stack) needs five times more CPU cycles than my solution. Additional CPU cycles are consumed in the kernel code and furthermore on the PRU side, before the message arrives. Not worth discussing.
I believe your use case is a special one and may not be served by remoteproc. Communicating between PRU and ARM in the main control loop seems odd. Normally, the tight control loop runs on one PRU, dumping to shared memory and the other PRU handles the communications between PRU and ARM. Why doesn’t this work for you?
A second point is the firmware load. Do you realy want to force users to use CCS and the Processor SDK (m$ habits on an open source comminity?). The PRU (and the other subsystems you target like DSP, …) are made for high speed tasks. My prefered language in that case is assembler, and I’m not alone in thinking that. Your solution needs a feature to load assembler generated firmware, if you still target to replace UIO_PRUSS anytime. And it’s out of question to remove and reload the kernel driver for firmware updates. What if one PRU should run while updating the firmware on the other? Furthermore it needs a feature to reload firmware with user privileges!
Here I agree with you. It should definitely be possible to add and remove firmware at runtime. Given that remoteproc can load, start and stop firmware, why not enable a feature for a user with the correct group permissions to load/reload new firmware at runtime? This might be done via a debugfs interface.
Also, your point about assembler support is quite valid and I would suggest that an assembler template/example be created for remoteproc. Alternatively, you can always start with a C version and then optimize the assembler output.
The next point is the messaging system and its big memory consumption. What if an application doesn’t need it and wouldn’t use it? Currently I cant find any feature for high speed data exchange between ARM and PRU via DRam or SRam memory.
In short, if you want to fulfill the expectations Jason Kridner or John Syne spend on your project (replacing UIO_PRUSS), you have to redo your concept and start from scratch.
Not true. I think the main framework is sound even if it does not suite your strange use case. Perhaps there is a way to augment the framework with a quick message transfer.
Just some thoughts from my side. In any case, thank you for your valuable input which I hope will guide Jason and Suman in their future development.
John
