Tool chains.
I had done some arm based development before and had used the arm-elf- tool chain. Looking through all beagle board related documentations, I see that arm-none-linux-eabi or arm-none-eabi are used. How are these two different? When is it appropriate to use one of these?
Can I use arm-elf- to compile and run programmes on beagle board?
I am trying to port an OS that was written as a project in an OS class(http://www.cs.ttu.edu/~pyeatt/cs5352/) to the beagle board platform. Any tips or suggestions that would help me get started would be nice :slight_smile:
Thank you
this should help for you…
http://www.codesourcery.com/sgpp/lite/arm/portal/kbentry34
http://www.codesourcery.com/sgpp/lite/arm/portal/kbentry37
you can use arm-elf- on beagleboard depends which OS you have on BB.
thanks,
amol
